For some reason on my friends 1981 Bronco, which I'm assuming has similar electrical systems to our cars, has a taillight condition where the brake lamps come on full, but there is no low bright brake lamps at all while the headlights are on. Is this a fuse problem or a switch? The light switch is pretty funky and flickers when you adjust the knob left to right.
Taillights not lighting, brake lights fine
what he said. check the fuses first just for the heck of it but its probably a switch problem.86 Lincoln Town Car (Galactica).
Hey, I just got done checking all the fuses and replacing the headlight switch and they still don't light. The bulbs are 1157's and look new. Brakes light up great so the circuit must be continuous...i dont know.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
the running light circuit is indepenant of the brake light circuit. you can have one without the other. I don't have a Towncar evtm to consult with but there is probably some connection between the brake lights and the headlamp switch, maybe down in the driver's side kick panel or something. Do your front running lights work?86 Lincoln Town Car (Galactica).
the front ones work yes, but I also just found out the back up lights don't work either.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
You said they flicker when you pull the headlight knob left to right - the rear markers do?? Did you have a good look at the headlight switch connector? Sometimes when they burn they mess up the connectors too... I think you can buy replacements.
Also, did you check the ground for the rear lights?? the brake/turn signal circuits could be finding grounds the marker lights can't use.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
check your grounds, probably the reverse and tails use the same ground point. 86EVTM shows all that, the fuel sender ground, and the license lamps sharing ground G301, which is "in trunk on LH wheel well". Its behind the carpet on the driver's side if the wiring hasn't changed much since 86. The tails and reverse lights also share C301, which is a connector in the LH wheel well, so check that while you're in there looking at the grounds.Last edited by gadget73; 09-14-2008, 11:23 PM.86 Lincoln Town Car (Galactica).
thanks guys, ill do that. Everything in the wheel wells is covered in mud, someone had some off road fun with this thing...1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
this will be inside the trunk above the wheel well, not in the wheel well itself. i hope the inside of your trunk isn't full of mud.86 Lincoln Town Car (Galactica).
I think you missed the fact he is working on an 81 bronco.. NOT his towncar.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarq View PostI think you missed the fact he is working on an 81 bronco.. NOT his towncar.86 Lincoln Town Car (Galactica).
