I saw those squares in mine as well.
Stuff Needed For Passenger Power Seat
Originally posted by 86VickyLX View PostWhat do I do to fix this?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Just rewire the existing switch harness. It's a lot easier than it sounds .... I discovered after installing a d/s switch to replace a broken p/s one that there's a little red tab on the plug that you can push in and pull the wires out. I then did a little trial-and-error with the six wires till everything was doing what I wanted and reinstalled the plastic part of the plug.
No need to worry about the seat bracket itself being backwards; the d/s and p/s switches mirror each other fore/aft.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostJust rewire the existing switch harness. It's a lot easier than it sounds .... I discovered after installing a d/s switch to replace a broken p/s one that there's a little red tab on the plug that you can push in and pull the wires out. I then did a little trial-and-error with the six wires till everything was doing what I wanted and reinstalled the plastic part of the plug.
And if the reversing the track isn't possible. Which wires are which on the switch? :lol: try saying that 5 times fast.
Reversing the track seems pretty unlikely because of the floor contour ... even if it's physically possible to bolt it down the wrong way, I'm sure you would have caught the mistake if you've ever worked on another power seat before.
When I put the d/s switch on my p/s seat slider, up was up and down was down, but front was back and vice versa. I really couldn't tell you for sure which wires to swap because I just pulled 'em all out and started playing around until it worked correctly.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostReversing the track seems pretty unlikely because of the floor contour ... even if it's physically possible to bolt it down the wrong way, I'm sure you would have caught the mistake if you've ever worked on another power seat before.
