Crazy assed wiring....
    OK, now the wiring is freaking me out, 12pm last night the passenger side, front window decided to
    work mysteriously after 3 yrs of not working......
    The seatbelt light and chime also started working magically then said fuck it and stopped a day or two afterwards...
    So am I lookin at a total re-wire of the electrical system or what?
    Also, when I start the car at night the headlight brighten/dim with the engine.....ANY idea on that?
    P.S-Battery is new, and the alternator charges so idk....
    -Wes
    sigpic1991 Crown Vic 351w 5.8L
    -Wes
    Do the lights brighten when you step on the gas? If they brighten it's fine. They all do that at idle or when at a stop, especially with the 2G alternator (don't put out good volts at idle) If those things that haven't been working are working now, I would just have to say that there are dirty connections somewhere
      -Wes
      Track down the connections of the things that are being finicky. I bet ya find some loose wires or some frayed wires or some messed up plastic connectors.
      As far as the headlights go, clean your connections at the headlights and do a 3g alt upgrade.
      The wire for the seatbelt light/chime is under the driver's seat.
        well, more news on this subject.
        The girlfriend randomly pulled up on the rear driver side door handle and after 2 yrs of not working it opened......Solenoid+bad connection methinks.....
        And 86vickylx, the lights do like you said, they brighten real nice like when I hit the gas while its in PARK, but when its in drive they stay the same.....
        Thanks mangs-
        -Wes
          I believe the window motors have a thermal lockout switch built in, when my old motor was weak and dying it would stop as it was struggling and then work again, maybe 15 mins or even a day later. On a side note, I thought since last August my driver power mirror had died, but when putting the new regulator in the other day I noticed the plug was undone, so when you get the chance check for a loose or undone plug.
          The chimes and seatbelt light are controlled through a box somewhere behind the ashtray. The plug could be loose for that. My chime speaker is dead but I hear it faintly sometimes. Theres a wire in the seatbelt plug that completes the circuit but mine had a break in it from age & use so the light would always stay on. I fixed the break but the light still stays on and oddly sometimes goes out. I just ignore it for the time being.
          For the headlights, I agree a 3g upgrade will eliminate the problem. Overall I think the wiring on these cars is pretty decent. The main issues are the 2g alt, headlight and ignition switch so keep them in mind. The only thing I haven't been able to fix yet is the seatbelt light.
          1986 Grand Marquis LS 2 Door
            The motors do have a thermal limit, and the brushes also wear out. Sometimes a good smack fixes them for a little while. I've got a rear window motor thats gone intermittent like that. Whenever it fucks up I just slam the door and it works again for a while.
              Yep that worked for me when the old one was dying, I'm pretty sure I remember hearing that tip from you.
