My temperature gauge has been reading well past maxmimum for a while now, so today at work I picked up a coolant temp sender.
I double checked to make sure it was the coolant temp sender by unplugging the original and watching the gauge. When plugged in the gauge maxes out, when unplugged the gauge slowly makes its way back down, then when plugged in again it quickly jumps back up to max.
After replacing it, it does the same thing. This is the fourth coolant temp sender that's been in the car since my ownership, counting the original. The second was a defect, and the third has lasted me about two years until now. I don't think there's really anything I could've missed, and the only real explanation is that I got another God damn defective piece of CarQuest electronics. Unless I'm missing something, this time a Motorcraft sender will be going in.
EDIT: Maybe this should've gone in the 5.0 section.
