Originally posted by Dereck
View Post
Automatic Headlight Wiring
I got the resistor and I will try to get the relay sometime this week.
Dereck I was wondering what the color codes on the headlight harness is.
Like I saw the brown wire for the parking lights and that's the only one I could see.
http://www.grainger.com/Grainger/items/1EGF4 I found a relay, I think this one should work. It's double pole, double throw relay. And, their warehouse (Grainger) is nearby so I can go to it when I get the money together. I can use this one right Dereck?
Originally posted by Dereck View PostHi 86VickyLX
Looks like you are on the case
Regards
Dereck
Also Dereck, I was wondering what the color codes on the headlight wiring harness is.
brown is the parking lights
red/black is low beam
light green/black is high beam
the headlamp power wire between the light switch and the MF switch is a red/yellow86 Lincoln Town Car (Galactica).
Hi 86VickyLX
You do not need to splice into the hi/lo beam wires you only need to splice into the parking lights and headlights wires from the back of the main light switch.
You need the following wires from the main light switch;
Brown = parking lights
Red/Yellow = headlights (to multi-function switch)
Tan/White = fused supply for parking ligts
Black/Orange = fused supply for headlights
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
Regards
Dereck
Big question!!!!! Do I need a switch at all? Like for example the push button switch that connects to the Purple/Orange wire on the Day/Night sensor harness. Do I need a switch at all? If not, what do I do with that wire?
Originally posted by 86VickyLX View PostBig question!!!!! Do I need a switch at all? Like for example the push button switch that connects to the Purple/Orange wire on the Day/Night sensor harness. Do I need a switch at all? If not, what do I do with that wire?
No you do not need a switch just ground the Purple/Orange wire from the day/night sensor and the autolamps will be always on.
Regards
Originally posted by 86VickyLX View PostOn as in when they are supposed to be on right?
Perhaps I should have said "The autolamp system will always be active whenever you are driving the car".
Regards
