Im thinking about purchasing a voltmeter for my vicky and just wondering is it as easy a people say to install, how would it be done i heard it run to positive and some how run to alternator? any help highly appreciated!!! thanks guys
Volt meter ?
yes the volt meter is the EZ one, just hook it up to any acessory juice that is on while the key is on.
Tapping into the ashtray cig lighter worked well for mePete ::::>>> resident LED addict and CFI defector LED bulb replacements
Cig lighter is usually constant +. The voltmeter uses tiny amounts of power though, so thats not really a problem. Ideally it should be key-switched though.86 Lincoln Town Car (Galactica).
Would fuse-holder with a voltmeter between the alternator and starter solenoid draw any with the key off?sigpic
1986 Grand Marquis LS 2 Door
Autometer says right in their directions NOT to hook the voltmeter to the alternator. Find a switched source inside the car; its simpler and more convenient.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
I was just talking about a regular in-line fuse holder that also has the display, not an interior gauge. Would that make any difference?sigpic
Originally posted by 86GmLsCoupe View PostI was just talking about a regular in-line fuse holder that also has the display, not an interior gauge. Would that make any difference?
I'm not so sure I understand what you're asking. There are fuse holders that display voltage on them (just to use for reference)? Is this a temporary thing, or is it always left hooked up?**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
I gotcha, its a fuse holder that displays voltage instead of the regular Mega-Fuse from the 3g to starter solenoid. I figured the two scenarios were sort of similar? I'm just concerned about a parasitic drain if its possible.sigpic
Originally posted by torquelover View PostOne wire to any hot switched source, one wire to a good ground, maybe a wire for illumination. Deciding on where to put it is the hard part.
Originally posted by Zcliff89 View PostIm thinking about purchasing a voltmeter for my vicky and just wondering is it as easy a people say to install, how would it be done i heard it run to positive and some how run to alternator? any help highly appreciated!!! thanks guys
Originally posted by 86VickyLX View PostI used the wires from the light on top of the ash tray for the lighting for it, and the feed source from the fuse panel. I used the one for the wipers. it was a metal circuit breaker. Then I grounded it on the main ground thing under the center of the dash. DO NOT RUN IT TO THE ALTERNATOR!
d'oh I shouldnt post after just waking up... I meant to say the switch line for the radio...
Currently I am using the cig lighter wiring to source a relay triggered by the radio's ignition wirePete ::::>>> resident LED addict and CFI defector LED bulb replacements
