Ok, I will start from the begining. Its a 1982 Country Squire. I love this car and I will NEVER get rid of it. But Its got me stumped. Ok It drives fine until the batter slowly runs down, and the engine begins to missfire then die. If I drive with headlights on and/or wipers it gets worse. Its as if the alt is not charging that batt. Change the alternator or regulator you say? This is what I have done: Battery load tested and passed puts out 12.8 with no load, engine off. Alternator belt tention and wires all ok. tested and passed. Tested with regulator bypassed and it puts out 14.0 volts. Regulator changed 3 times. Voltage at the headlights, wipers, and interior acc is at 10.00 volts. everything dimms when I press the brake, use turn signal, or run the wipers. engine dies when I
turn on all acc. what else could I check. Yes all grounds inspected and cleaned.
