weak heat
    i hate how htis thing only opens on those two settigns now though im happy it works. i mihgt prop the thing on recirculation for the winter cause i hate having luke warm to cold for all the setting but vent.
      i still think im having a problem wiht the heat on my car. it works fine on recirc but if i have it on floor, defrost, vent or floor and defrost it comes out warm or, well not cold but cool ill say. im wondering if theres somethign else wrong with it but im not sure. is this normal for a car that doesnt have ATC?
        What temperature thermostat do you have? How hot does the engine actually run? I've got a 180 in mine, and it runs at 180 on the gauge. heat is fine, and my recirc door is not open, its sucking outside air. It had good heat before I replaced the core too, and the cooling system on my car was totally un-maintained for a very long time. Chock full of mud it was.
        ATC and non-ATC put out the same amount of heat. Only difference is how the blend door is opened. I guess its possible the cable is out of adjustment, so you're not actually getting it fully into the hot position but thats really all that comes to mind.
          hmmmm. i put a stock temp thermostat in and ive cleaned out the cooling system cause it was full of mud. the motor seems to run at normal temp too. i know the old thermostat was dead and never let the motor warm up at all. idk what to check at this point.
            well it wasnt even below 45 tonight and i put my heat on high and it felt like it was barely working. like it works but it doesnt feel strong. i know if i slide the lever all the way to hot kinda hard it feels stronger. i kno my heater cor isnt clogged cause last year i flushed it with a hose. i almost wonder if i should just chang the heating/ac console? like maybe the lever isnt working riight or the blend door cable could be stretched. im running out of ideas and with winter coming id like to have good heat
              I had the same problem on my car... turned out the cable operating the heat door had slipped and wasnt pulling the door fully shut. if you pull the glove box out, you can see the cable and heat door "arm". use some long needle nose pliers and pull the cable tight so the door closes all the way.
                You really should flush the heater core by it's self. Just unhook both hoses and run the water hose in both hoses (one at a time). If the flow is good both ways the core should be good. When you flush the rad. just hook both heater hoses together and flush away. The reason it should be done that way is, if you have a bunch of crap in the rad. you don't force it into the heater core and plug it up.
                  thats how i flushed the heater core last winter. ill have to try the cable idea
                    anybody have pictures of this??? heater in one of the cars here is very weak and both heater hoses are same temperature. both are hot. i bought a new 180* t-stat to install if needed, but since both heater hoses are hot, i am leaning toward the controls or a door for the heat. pics are helpful if anybody has any.
                    Addicted to 86-87 Panthers
                      well, im still havin problems with this. it was fine for a while but today i decided to feel the heater hoses and the one going form the water outlet was hot and the one going to the waterpump was cold. like it felt warm but not like the other hose.
                      so yea im thinking the that my heater core is clogged. damn bitch that had my car before me had shit in the coolant so i bet that clogged it.
                      so i guess my question is, how much stuff has to come off hte car to get to the core? i had one guy tell me that we can pull the blower motor and the evaporator and all that stuff off the firewall and theyll be a big enough hole to get to the core anod not have to remove the dash and all that noise. i just didnt know if thats true btu i hope so or i got some work ahead of me. this nonsense sucks
                        Clogged heater core. Try flushing it backwards before you resort to pulling it out. Flow is from the intake back to the water pump. Pull both hoses off and try flushing through the water pump side with a garden hose to see if crap comes out of it. If its not leaking, I'd definitely give that a go to see if you can at least get heat for the winter, especially if you have no way to work on the car inside where its heated.
                        No you cannot access the core from the engine side. It comes out from inside the car. You can remove the plenum, or you can unbolt the dash from the car and extract the core through the top, your choice. Unbolting the dash is probably easier than working underneath and sneaking the plenum out through the bottom. Either way, its a time consuming job.
                          well i did switch the hoses around and the heat works a lot better. like even my floor vents give out heat. before all i got was cool air. like its not the same temp as outside but it still felt cold. so as of now my heat is working good. maybe somethign was clogged in htere. i just hope it keeps working good but ill find out for sure hte next really cold day that comes up.
                            well that was not what I meant, but I guess it works. Unfortunately now if you did disloge any crud, its in the cooling system. What I said was to use a garden hose to flush it, with the idea that any crud would be flushed out onto the ground, not back into the cooling system to clog up something else.
                              i know. i flushed it last winter with a hose and it didnt do much. i was in a rush and just reversed hte hosees. i knew i was possibly causing another problem just revering hte hoses but i was in a rush even though thats a sucky excuse. tomorrow ill check my radiator and see if anything came of it.
                              i did think that all i couldve done is freed some stuff up and now its on the other side of my heater core.
                                Depends how you want to access the core. You can drop the steering column, the dash, and pull the box holding the heater core in out far enough to remove the core. It's the way I did mine.
                                You can supposedly pull the entire air plenum out from underneath the dash, but I'm not sure how that procedure goes. Either way it's a pain in the ass.
