And I don't know if its the one I need. It is this big blue plastic contraption with a few vacuum line hose nipples and a 2 big holes in either end, one end has a foam o-ring. Cost $53 from Ford. I'll have a picture up soonish. Does this sound anything like the ATC sensor? If so how do I replace it? In other news I got rid of the Thermal blower lockout and my heat comes on now! yay.
Soo I bought this A/C Temp sensor...
that's it.....pull the dash pad off to get to it mang
Ok cool. thanks!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
yup, the temperature sensitive calibrated vacuum leak. absolutely idiotic design, but when the sensor is good the system works pretty frickin well.86 Lincoln Town Car (Galactica).
It works!!!!!!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
yeah heat sometimes I wish my car had manual not the auto stuff. I never set it to auto anyway
I need to get one o those for the 85... cant you clean them????Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
buy a new one pete
cleaning works sometimes....get a new one before there are no more in teh panther parts bins
yeah actually mine was clogged up with leaves and moths when I found it, lol. But I vacuumed it all out and it still didn't work, so I replaced it.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Yea, they seem to die randomly and like Scott said, I think when they stop working you should get a new one. Just make sure you try someone like Teamford so they only run you around 30 or so. I'm tempted to buy a spare just in case. All in all, I think the ATC setup works very well. It keeps the car at just the right temp and I never have to bother with the settings.sigpic
1986 Grand Marquis LS 2 Door
Originally posted by gabegt90 View Postyeah heat sometimes I wish my car had manual not the auto stuff. I never set it to auto anyway
Pete: cant really clean them. They have a rubber diaphragm under a metal plate, basically the plate warps and allows more or less vacuum across. When they fail, usually the rubber isn't pliable anymore or its ruptured or something, so it allows full vacuum across it. Thats the no heat failure.
Its sort of a mickey mouse design, but I guess it works. Later ones used an electronic temperature sensor and climate control head, and moved the blend door via an electric motor that seems to be a lot more problematic and is a hell of a lot more involved to replace than the stupid sensor in our cars. Basically to do a blend door servo in an aero model, you're doing pretty much the same work to swap a heater core.86 Lincoln Town Car (Galactica).
partsguyed.com for the part
changing it requires you to remove the dash pad
Originally posted by DiVin3 View PostIm having this same problem...Where can I find this piece and how do I change the pieces.
It is that blue thing with the screen and the cable attached to it. I believe two 7/32 bolt hold it...though I am not positive that is the size. I know for sure though that it is an oddball size though.~David~
Make sure you clean out the tube that comes form the fan to the blue thing. It will get full of dirt and crap. Sometimes that is the only thing wrong.
I got mine for Green Sales Co. The have all kinds of parts for Fords. They buy old inv. from Ford dealers. 1-800-543-4959 or greensalescompany.com.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
