I just snagged a Mark 8 fan from eBay. I know I'll need a controller to make it work properly. I was thinking about trying to hook it up this way, please tell me if it's possible or necessary.
I'd like to use a switch on the dash to control whether the high or low speed is used. I figure during traffic or especially hot days, I can use the high setting, and use the low setting the rest of the time. This will keep the power consumption down, and allow the fan to not have to cycle as often. I'd also like to have another switch to allow the fan to run on low speed with the car turned off, to help with cooling between passes.
Again, let me know if it's possible or necessary, and what parts I'd need to make it happen. Thanks!
