how to make digital dash speedo go up to 188mph
    I saw a long time ago how to make it work, I just can't find the old article.
    Its a maybe. Its for a different kind of speedo so no idea if it will actually function. Let me know if it does work though.
      the circuit board for the cougar speedo looks very similar to the tc one but the little glass pod thing on the tc ones cover the numbers and everything else on the circuit board. I've been meaning to get a second one to tear apart and rig to go past 85.
        Will your car go that fast?
        1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
        FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
          in canada you dont have to make it go up to that, it alredy dose, are speedos go to 110 mph to on the analog ones
            Ahh, I forgot aboot the kmph thing.
            A Canadian Chrysler (not dodge) intrepid came into our shop the other day.
            I glanced at the dash to read the odometer and the 220kmph speedo caught my eye.
            It looked so cool, a 200+ speedo on a factory car, but It's probably common over there.
              yea its common here
