I just went out side and started to crank the car up and poured a little of gas in the carburator and all it did was turn over.....Im finna take this car to the junk yard.
Where is the fuel filter?
Don't give up that easy!
In order to see if your fuel pump is working, remove the fuel line from the carb, and let it drain into a cup. Then, disable the coil wire, and have a friend crank the motor over. If gas starts rushing out, then your fuel pump is working
Try that.1983 Grand Marquis 2Dr Sedan "Mercules"
no lift.
Did you put gas in the car? It didn't run out while you were driving around did it ?86 Lincoln Town Car (Galactica).
Yeah, there are some areas just not designed for hands to fit into. Potentially dumb question ... you are using a socket wrench with a 6-8" extension? Even pulling starters turned into a relatively quick job once I realized I had enough extensions to position the ratchet where I could actually turn it.2012 Mazda5 Touring | Finally working on the LTD again!
