what a jip!!! call em up and demand a sender lol
Complete box panther gauge installation how-to
This is a sticky topic.
I forgot the pictoral tutorial on the Sunpro LED backlighting... silly me.
you sure can! They have lots of 194 LED replacements on Ebay.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Only thing with LED bulbs is they tend to be a bit directional. The lighting might not spread nice and evenly like standard bulbs.86 Lincoln Town Car (Galactica).
Actually, depending on the cluster, you might want the directional type bulbs. I noticed in the 90-91 speedos they use fiber-optic like materiel to channel the light to the outer face of the speedo. The little collector sits right in front of the bulb, so it might work better like that.
My older speedo doesnt work like that , so I used a side emitting style (inverted lense) LED replacementPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Hey, Installing a tach. What's a good place to put the wire from inside the car to the engine bay? Didn't see it if you posted it.1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
Supermotors
i ran my wires through a hole near the brake boosterPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Dumb question, but what are the thread sizes for the senders? For example, 1/2" by 14npt.... What is ours? I'm referring to the oil pressure and the temp gauges. I'll have to determine trans temp at another time lol. The reason I ask is because I'm looking next year to install a set of Dakota Digital gauges(trans temp, volts, oil pressure, coolant temp)right above my hvac controls. Unfortunately they do not come with senders.Save a seal, club a liberal.
oil pressure is 1/4" NPT pipe thread. Not sure on the temp sender but its a standard size. I want to say 1/2".86 Lincoln Town Car (Galactica).
Originally posted by 85crownHPP*TACHOMETER
the only hard part is figuring out where to put it!
simply tap into the coil, here it appears to be in the green wire.
How hard is it to get through that hole in the firewall and under the dash? Anything to watch out for?
What did you use for a key on power source for the tach? Also, what did you tap for the light source?
What gauge wire should be used to extend the tach wire to the coil?
One more thing: Will hooking in the gauges interfere with the EFI comp? Do I have to set it up so that the idiot lights and wiring are still connected?86 Lincoln Town Car (Galactica).
