I have noticed that the air movement by the stock fan on "high" setting is hardly adequate to cool such a big cabin in the summer. Is there any way to speed up the fan motor? or possibly replace it with one from a newer Panther? Has anyone else noticed this?
making the AC/Vent fan blow more air
The faster the air moves over the evaporator the less cool it will be. Whatever setting recirculates the air is the best bet because it does not have to push the air into the car, and the air is cooler.Builder/Owner of Badass Panther Wagons
Originally posted by mrltd View PostThe faster the air moves over the evaporator the less cool it will be. Whatever setting recirculates the air is the best bet because it does not have to push the air into the car, and the air is cooler.
try you're A/C with a low or medium blower setting you'll be amazed at you're erecting nipples
always use MAX A/C, that's the mode the recirculates1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
Originally posted by boXman View PostYou ATC guys have one less speed than non ATC...sucks for you! :p86 Lincoln Town Car (Galactica).
oumight not be recirculating on max... look under your glove box to the right and you will see a vacuum can, make sure the vacuum line running to it is connected, sometimes they can be kicked off by a large foot.
you can also get a new fan motor at autozone for about $20 that will blow harder - they do wear out.
you mean i can go to Autozone, give them 20 bucks, and I'll get one that will blow harder? well shit I know where I'm goin tomorrow!86 Lincoln Town Car (Galactica).
Yea, like they said the recirculating is the most effective, so use Panel for max cooling, and Hi/Lo as you next best bet (pulls in some fresh air as well). The autozone blower may be a good bet, but I'm real finicky with aftermarket parts. You can try Four Seasons brand (which may be what Autozone sells?), which I've had good luck with, or one of the online OEM stores like Teamfordparts. My air has still not been cooling well either, the lowest temp I can get is 48 F. The temp also varies greatly whether I'm accelerating or idling (blows warmer air at idle, cooler under some load).sigpic
1986 Grand Marquis LS 2 Door
Originally posted by gadget73 View Postyou mean i can go to Autozone, give them 20 bucks, and I'll get one that will blow harder? well shit I know where I'm goin tomorrow!
I think you totally missed what I meant by that post lol. Thats what happens at 2:30 am after working 12 hours.86 Lincoln Town Car (Galactica).
My attempts at innuendo have clearly failed. I quit.86 Lincoln Town Car (Galactica).
