Of course, the ATC in my Wagon isn't working properly. Here are my symtoms:
- Hot air out of the dash vents (the ones used for vent and a/c) all the time, regardless if the system is on or off.
- The more the load increases (vacuum decreases), you get more hot air out of the vents.
- Something is constantly moving down there in the heater case, squeaking as it moves. Maybe the blend door (reason you get more heat and hotter heat going up a hill?).
It's like it's stuck in the vent position and the blend door is stuck on heating. The defrost position still works, but its still hot air.
What do yall think is wrong?
