School me on some car audio basics, please.
    For a little more info... the eXcelon amps in mine are rated at 22 watts rms and they get plenty loud for me. Since I have no idea about the amp in the Blaupunkt, I don't know if it'll clip like that Pioneer I put in the Mark VI does. Looks like the Pioneer you have in the list is the same basic ratings as my eXcelon, so it might drive the Kenwoods a little better than the Blaupunkt. Obviously, testing that for yourself would be the real decider.
    How much of a gap in rating needs to exist before clipping is a risk?
    I'm assuming that's something along the lines of a speaker pulling more current than the deck can provide, and the deck's built in amplifier cuts out as a protection feature? Or if not as a protection feature, simply due to failing to keep up with the demand?
    I'm assuming that,
    • if ratings are close together/well matched, clipping either won't happen at all, or only happen at very high volume during a time when a lot of sound is being produced
    • the wider the gap in rating (e.g. 100W speaker and 20W deck vs 30W speaker and 20W deck), the lower in volume level the clipping would begin
    Or am I way off here?
    The Pioneer I listed, I actually have two of. One in the 83 MGM, one in the Ranger. It has very close to the right green for Ford stuff and it has front panel 3.5 in, so although it doesn't have the desired looks, it does hit some requirements. I probably wouldn't bother to spend money to replace it if I can build something decent around it.
    The 83 is a less-ideal case study, as a car. It is a 4-speaker car, does not have door speakers. Cutting the door cards isn't really something I'm super interested in doing. Making a decent result using just speakers in the dash and package shelf would be nice.
    | Junkyards
      Clipping is an issue with amplifier design. Many amplifiers are rated on peak values and typically 80-85% of that is actual peak without clipping. Some bad designs are more towards 60-70%. Most major brands fall into the 85% area. So with speakers rated at 30W, being able to drive them at 80% will get you well into the 120db range typically so 50% should be at least in the 85db range from my experience with these budget type setups.
      It is better to match RMS values as close as possible and ignore peak values since those are pretty much meaningless in the grand scheme of things. But I haven't found any 20W RMS speakers that are worth dealing with that don't cost over $200 a pair, so I deal with the mainstream types. A spread of 30% below 50W is fine. Would be better to be closer, but it will definitely work. And it's always better for the speaker to have the higher power rating. Less chance of blowing up stuff. My subs are a good example. Amp is rated at 130W RMS and the speaker at 135W RMS. Peak values are way out there at 800 and 350... but the amp rating is in bridged mode (stereo to mono) and I never use that mode.
      in short... 30W speakers will do fine even on 15W of clean drive for casual listening unless you're on a grooved highway with huge amounts of road noise.Then you may need to push to possible clipping territory. Clipping can be reduced by lowing the bass since it's the big power hits that cause the clipping since the capacitors aren't large enough to fully sustain the amp's power rating if it's clipping.
      I've seen good sound from Sony speakers, but I've never used them personally. I've also seen good things from Kicker. But that was mainly low end augmentation of a setup that has good highs and mids already. And yeah, just add decent speakers to the vehicles with the Pioneer units and you'll probably be fine.
        edit: replied at same time as you Derek, reviewing your post, but wrote the below first.
        So, what should I be looking for in a speaker to attach to the following options:
        • The factory premium non-JBL system
        • Blaupunkt Milano with the factory amplifier present
        • Blaupunkt Milano with no external amplifier
        • Pioneer DEH-1900MP with no external amplifier
        Is there a wattage+impedence+decibel range that covers all of these applications?
        Just picking some favourably priced examples, what do we think of
        The Kenwood KFC-1366S has a lousy sensitivity rating of 89dB, the second Kenwood's are nearly identical at 90 and the MTX's are the worst at 86. That's a big enough gap such that if you paired those MTX's with either Kenwood, you'd notice the Kennies playing louder over the MTX's. Also kind of why speaker matching is important, at least in the sensitivity and impedance department.
        Anything with an external aftermarket amp should play fine with any of those modern speakers rated at 2 ohms. A factory amplifier might have some issues with them at higher SPL's due to the extra current draw. You might end up blowing the fuse for the amplifier, running it hotter and also if it's tied to the same circuit as the radio, you might see the lights flicker. That is unfortunately a case by case basis. For example, I had to put a CDM (the amplifier section of GM truck radios from 1988-1994) from a 1994 GMT400 in my K1500 as GM redesigned it for that year. It's got stouter heat sinks and more magic smoke inside, so it handles those Infinity plate 4x6's I put in it much nicer than the period correct CDM. What that means is it sounds a bit nicer, doesn't break-up as quickly and the radio's display doesn't dim as much as it did before with the old CDM.
        I'm glad sly pointed out the RMS rating of the one amp, 22 watts RMS. When I bought my first couple radios, I spent extra money getting the ones rated above 20 watts RMS because I thought it made a significant difference and (unbeknownst to me at the time) would give me better headroom. Well, if we go back and look at the numbers for wattage & SPL output, you'll find a 22 watt RMS amp is no better than a 16 watt RMS amplifier. Market-wank-a-teering, all that is. Most audioholics measure headroom in dB, and they tend to want 6 dB of coverage. Doesn't seem like a lot, but it is depending on your average listening needs. Let's say you went through all the trouble setting up your high pass filters right and find your system is comfortable producing SPL's on average of 105 dB. However, to make it interesting, let's say you got there with those awful 86dB efficient MTX speakers.:
        1w rms= 86dB, 2w=89dB, 4w= 92dB, 8w= 95dB, 16w= 98dB, 32w= 102dB, 62w=105dB, Damn, nearly100 watts RMS needed just to achieve 105dB with those skag-nasties.
        ..So you want 6dB of headroom? You need to take that last power figure and double it, so 250 watts RMS per channel is what you'd need to comfortably drive those crap-tastic MTX's. But they're only rated for 20 watts. So now you can see how that speaker really blows. By the specs, it's only going to be comfortable pushing 99 to 102dB. Don't worry too much about a speaker's max RMS watt rating. You'll be more likely to blow a speaker by underpowering it than you will by overpowering it. Amplifiers that clip essentially send square waves to the speaker when they should be receiving sine waves. When you feed a speaker a square wave, that'll overheat the voice coil and that's where you run the risk of blowing them up. Of course, you can do the same to cheap materials by overpowering them as well, it's just not as likely due to peak wattage figures happening infrequently and average RMS values being much lower.
          the whole clipping melting speakers thing is not as much of a problem as people make it out to be. By the time its doing that it sounds so god-awful that anyone with ears that work will turn it down. if your ears don't work you probably won't notice the tweeter being fried anyway so ultimately it doesn't matter.
            Yeah... this is why I try to match nominal (RMS) power per channel/speaker. This is mainly for durability as you're not going to blow up speakers if you can't overdrive them. I know audiophiles tend to like to get amps way over the ratings of the speakers so they can drive them with ease for the most efficiency and clarity in sound reproduction and are very careful to always turn the volume down after listening to something, but I don't care if I have a little hiss when I crank it up. When I want it loud, I just want the neighbors to enjoy it too... without clipping.
              Not quite. If you've reached the point it starts to sound that bad, you are REALLY clipping the amplifier. This is the reason I will not buy amplifiers for my main listening system upstairs if they do not have clip lights. Big fan of Crown, but can't vouch for anything of theirs that is super modern. I am running a Studio Reference I and II.
              The hiss is generally a byproduct of your components' Signal to Noise Ratio or Hum & Noise, the higher the better. My general rule of thumb is not to buy anything with a SNR of <100 dB. They'll always hiss some what- hell, most material recorded before the digital era already hisses to beat the band. Yay tapes! The intro to "Immigrant Song" by Led Zepplin is about as awful as it gets. Anyway, Crosstalk is another one, which is why a lot of audiophiles move to mono amplifiers for each channel they want to drive. Cross talk is essentially when the left channel's signal bleeds into the right and vice versa. Stereo separation/presentation is improved immensely by moving to monoblocks or amplifiers with that rating at or above 100 dB. Of course, bridging an amplifier effectively makes it a mono block and thus enables you to throw that rating out the window.
              As for blowing speakers, I like to take the max RMS power rating of a given speaker, multiply that by three and then use the result to determine how much power I need to effectively drive said speaker. Of course, none of that matters if all you want to do is casually listen. But if you're going to jam like I do, that's a good practice to follow. For example, I had and still have a set of JBL LX44's. Their maximum power rating is 125 watts. Pssh, I fed them nearly 400 and they rocked like they never had before without even bottoming a woofer. I didn't run a high pass filter on 'em when I did that either, I was really impressed. Again, you're more likely to blow a speaker by underpowering it than you are by overpowering it. Also, just because you have 400 watts or more available, doesn't mean you're using them. What you're actually using at a given SPL is approximate to those rudimentary calculations I posted earlier. When you think about it, it's kind of like horsepower.
                True enough. Though all amps have hiss if you push them far enough (learned that from an audiophile amp producer) which is why more power on the amp and less on the speakers for audiophile systems. The better ones just don't show it until you're at ear melting levels and it's still less than the stuff I use. I am pretty much the definition of the casual listener. I want it to last a long time and don't get affected by me being silly with it. And when I say blowing speakers, I mean literally forcing voice coils out of the cones (seen a few folks pull this off pushing 5-10x the power through speakers) or fusing wires in a flash by overpowering them. Underpowering them and current melting the wires together is a different story. I've never had that failure because I keep my stuff close to, if not matched. I've also never blown a cone out either. I've had surrounds disintegrate from age though. I did fix my mom's old Fisher tower speakers from cat scratch damage. Still running strong after 40 years. And as much of a bass head as I am, I still try to balance my lows with the ability of the system to produce the highs.
                  Guys that turn their systems up without any signal just to listen for hiss..
                  ..That's laughable because if you measured the volume of that hiss at a given point and then fed the same system a signal and measured that signal's playback volume- worlds apart and thus a red herring in audiophile land. At that high of an SPL, your ears begin to compress or whatever anyway, which is to say they aren't picking up the resolution & detail from the music as well. At first, I didn't understand why people would take the monitors I have and feed them ~10 watts from a tube amp. Then I got a better preamplifier and main amplifiers- I find myself listening to material I previously never gave a second look at <80 or 90dB just for the dynamics and how amazing it sounds. So by that, I'm not even using 1 watt with my monitors, the subs might be using 5 or 10, but they're pretty forgiving in that department. Sooo, now I'm wondering just how much more buttery and magnificent things would get if I tried a tube amp. Catch-22 for me though, because as it starts sounding good I tend to step on the gas.
                  ..If you want stomach punching tight bass, look for amplifiers with really low output impedance. If that spec isn't posted, pass.
                    OK, so how's this for a shopping cart for a 6-speaker car:I have a friend printing up some of the BMW adapter rings previously mentioned in this thread so 4" is the way to go for the dash, I believe.
                    The mismatched Infinity is the result of the Kenwood Sport Series offering (KFC-1066S) in 4" having 88dB sensitivity, otherwise I'd do those for the door for brand matching as recommended here.
                    There does appear to be some marketing stuff about how sensitivity is measured and it sounds like Infinity and Kenwood maybe measure it in different ways.
                    It's not clear to me that the 1666S (6.5") actually fits in the door of a Panther which has the plastic speaker mounting insert.
                    The Crutchfield catalog is also giving me grief about 6x9 vs 6x8 for Mercury vs Lincoln applications - but the hole in the car is the same size, so I'm not sure what to make of that. I want something that I can mount using the silly rubber strap thing the factory used, and I want it to stay hidden in the trunk, not cut a hole in the package shelf for it to poke through.
                    Bear in mind I am looking for a cost effective way to achieve something that sounds like a modern vehicle's base system. I won't be sad if I overshoot that a little, but what I'm trying to achieve is a lot less than what most people are.
                    edit:
                    with above being asking about a 6 speaker car - let's say I don't want to add door speakers to my 83. Would the Infinity, the Kenwood, or something else entirely be the right choice for the dash in that car?
                    | Junkyards
                      I'd just skip the dash speakers. If anything, you're going to want those to be the lowest in sensitivity, unless you want to be irritated by them. The fact they fire right into the windshield isn't ideal either.
                      Also, I'm not entirely sure, but I read somewhere the door and dash speakers are run together in parallel with boxes. If true (I believe it is, as I never ran additional speaker wire and yet the dash speakers worked in my Townie) that will reduce the affected speakers' impedance by 1/2. So that dash speaker will become a 1.5ohm'er instead of 3 and the door speakers 2 instead of 4. As far as the amplifier is concerned, I'd want each channel to have the same load. So if you're going to run dash speakers, make sure they end up with the same resistance as the rears. As your selection stands now, you're looking at 3.5 ohms for the front and 4 for the rear. I can't speak to the sound quality of those, but the seeing as the rears are three way and have a tiny magnet, I wouldn't go with those. Tiny magnet could be neodymium, but the critical thing here is that the stock rubber rings which hold 'em up back there might not play nicely with them. Height is also important, try to match that with the factory units. Worth noting I didn't pay attention to that & didn't have any problems. Also, because of how they mount, you can totally run 6x9's- I did.
                      Edit:
                      Look into these 6x9's:
                      Infinity Reference REF697F Infinity Reference 6"x9" 2-way car speakers at Crutchfield
                      Goofy 3 ohm rating they claim turns into 4 thanks to your speaker wiring, but boasts an efficiency of 94dB, a significant and noticeable improvement over the Kennies
                      Look into these 6.5's for the doors:
                      Infinity Reference REF607FSL (shallow mount) Reference Series 6-1/2" 2-way car speakers at Crutchfield
                      Same family as the 6x9's I linked along with higher efficiency, 3dB over the Kennies.
                      Sure, you'll be spending twice as much, but I'd be willing to wager you'll be happier with the Infinities. I can't speak to their sound quality as I've never heard them, but they'd be the first set of speakers I'd want to audition if I were in your shoes.
                        You want the dash speakers, but low sensitivity is fine.They are closer and the sound reflects off the glass so you will hear a lot more out of them at a given power level than the door speakers. They really only operate as tweeters. Or you could just mount component tweeters up there with a crossover. Treble doesn't really work from the doors unless you re-locate your ears to your shins.
                        The dash and door are in parallel.
                        6.5" will fit the door but only if you remove the adapter rings and mount them flat. The adapters (on Lincolns at least) reduce it to a 5 1/4" but with a slight upward angle. IMO the smaller speaker at an angle sounds better. I don't know about Ford or Mercury door cutouts for sure but I think they have no mounting rings and sit flat. probably limited to the 5 1/4" there.
                          I would also suggest installing a boom mat speaker baffles on the door speakers just for weather protection. Any acoustic help it provides is pure bonus, but the water protection is an absolute.
                            I don't think those Infinity 6x9s can work. The surround pokes out proud of the top of the speaker, which makes installation in the stock location impossible without making some sort of spacer to set it further off the sheet metal. The Kenwoods do not have this problem.
                            In a car that does not have door speakers, and will not be modified to have any, is the Infinity 4" a reasonable choice? Or does this question really come down to which option ends up in the package shelf? e.g. Kenwoods in the package shelf = Kenwoods in the dash.
                            Ford/Mercury do get the plastic mounting rings for the door speakers but I believe it might be a 90+ thing. My 91 has them.
                            Boom mats are being considered. Even with fully functioning dew wipes, these cars have very wet doors compared to a lot of stuff, so it seems wise.
                            | Junkyards
                              On dash only setup... the Infinity speakers may be fine. Might have to adjust the front/rear bias to preference a little more than using the Kenwoods. I do know that anything in the dash that actually can do anything below 100Hz tends to buzz things, so using the built in crossover on the headunit (if it has that) is a good idea. It also helps with longevity as well. The Pioneer 4 inch speakers I used (still have them, but mounted in detachable boombox speaker cubes - no longer have the center section) were suited for purpose for casual listening, but didn't have the really crisp highs (that's ok for me since my ears tend to exaggerate stuff over 14kHz). It's another one of those "what and how do you want to hear it" things. Having the dynamic range though is nice for some tracks as the high harmonics help fill it out in a way the stuff I listen to fills out the low end. I tend to prefer to use the same brand all around if I can as that will usually mean things react the same all around since the coil/cone types and ratings are all similar.
                                With the 84 Town Car being in the garage, I started messing with this tonight.
                                I had forgotten that I previously pulled some Pioneer speakers from a junkyard car, so I've been testing some combinations of stuff.
                                The Town Car retains a stock "Premium Sound" 4-preset radio with not its original, but an E4-numbered football amp.
                                I'm fairly sure none of the stock speakers in the car are actually original and I've swapped them all at some point, and may not be matched to the overall system.
                                For the rear 6x9s (and indeed, the factory speakers are 6x9 and not 6x8 like Crutchfield occasionally believes):
                                Both the Pioneers and Kenwoods sound better, all-around, than the Ford speakers.
                                The Kenwoods are what you might refer to as "brighter" on the highs, while also kicking a little more on the lows, which to be honest surprised me as their magnets are the smallest of the options on the table. To my untrained ear, the Kenwoods sound like a good "full range"/"do everything" speaker, at least the 6x9s. I am content for the Kenwoods to stay in this position.
                                For the door speakers, the Kenwoods are just okay. They just barely edge out the Ford speakers on average but there are definitely things the Ford speakers seem to do better (mostly, bass). Also, a 6-1/2" does not fit the door speaker brackets as gadget noted, but a 5-1/4" is definitely on the small side, so it's another case of Ford inventing a speaker size I guess.
                                For the dash 4" (or whatever they are):
                                With the Kenwoods in the doors, the dash sounds best with no speaker installed.
                                With the Ford speakers in the doors, the dash sounds best with the Ford speakers.
                                In any configuration, the Kenwood 4" in the dash are way too high. They really strictly enforce the sensation that only some of my sound is coming from each area of the car, which is something I was specifically aiming to avoid.
                                The Pioneer 4" are a decent middle ground, sounding a little more moderate (though, those were only in the car while the Ford door speakers also were at the same time).
                                So I think the junkyard-harvested Pioneer 6x9s, and 4", are going in the 83 Grand Marquis which does not have door speakers. They should sound at least a step above what's in that car now, which sounds very "flat" in general.
                                Which means the inventory of things pans out as follows:
                                • Junkyard Pioneer 6x9: to go in 83GM
                                • Junkyard Pioneer 4: to go in 83GM
                                • Junkyard Koss 6.5: available
                                • New Kenwood 6x9: 84TC
                                • New Kenwood 5-1/4: 84TC (installed with Boom Mats)
                                • New Kenwood 4: available/may investigate return to Crutchfield if option exists
                                Cars not yet addressed which I'd like to look at:
                                • 85 CS: fundamentally the same setup as the 84 TC except being a wagon the rear speakers aren't 6x9. Might want to try Infinity for that one.
                                • 91 GM: what's in it is usable but maybe if Infinity stuff blows me away in the wagon I'll go that way with this one.
                                • 89 Ranger: to be addressed once it has an engine
                                • 91 Acclaim: it's truly abysmal but a fair bit of it may just be absolutely trashed bal/fade pots. Was a factory Infinity system but nothing of that stuff remains. Not even sure what this car's future is with me, but it can't sound awful if it's staying.
                                Oh, and those BMW speaker adapter rings - they work but they don't match the screw hole pattern on the car so only 2/3 screws can be used.
                                The junkyard 4" Pioneers have Scosche adapter rings on them which do directly fit the hole pattern in our cars.
                                | Junkyards
