Morning.
I'm new here (posting) but have been reading a lot for several weeks. I recently ran into a little snag on my 1990 GS. I needed a new turn signal switch because the Washer Button had stopped working. I ordered the new part and installed it. All went smoothly until I turned on my headlights and ONLY the parking lights came on. I could push the signal arm forward and the LOW Beams would come on or click it back and the HIGH Beams would come on. Everything else on the switch worked just fine so I put the old switch back in and all was back to normal (except washer). I've noticed there are quite a few replacements for the signal switch and a lot of different part numbers. I looked at the compatibility charts & my car is there, but I still wonder if there's a slight difference in the internal switching or something causing the switch to knock out my low beams on my headlight switch?
Any thoughts would be appreciated.
Thank You.
Thank You.
