I am seeing a slight misalignment of the belt since I did the 3G swap. The belt is not too happy riding like this and explains that slight burning rubber smell under the hood from time to time. I used a Taurus donor.
The alternator is too far back and the belt pushes to the front. I maxed out the adjustment bracket at the intake to push the alternator bracket as far forward as possible. Still having the issue. Maybe I can put a shim under the pulley?
Anyone else have this issue?
