Can’t read codes
    Can’t read codes
    On my My 87 wagon i Can’t read codes
    Has that model reader ever worked for you before? I have a slightly older Actron, which IIRC I bought on your advise. You r welcome to try it.
      ever try the jumper wire and blinky light method? Curious if it does anything, or gives something completely bonkers.
      also in there is what to check if it won't give any codes.
        Reader worked before. I hear fuel pump prime then clicks then no codes on reader.ill check what’s on link
          I had an ECM that wouldn't talk. Ran like a top though. Swapped in another ECM that didn't have a burnt diag trace internally.
            wonder if someone jumped it to +12v instead of ground to read codes
              Considering the redneckery under that hood that I had to fix after I bought that car... probably.
