When ignition is off wiper interval, box makes noise when wiper switch is off and won’t shut off wiper motor with power on or off
Wiper problem
So wipers run all the time?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I would have to check some schematics but I suspect the switch is supposed to be depowerd when ignition is off. Though it may just switch ground. The diagrams should give some good ideas. Do you have an evtm? Also what year is the wagon?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Maybe post up relevant pages.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
- Likes 1
Hurray for easy (re: cheap) fixes!
Jack
Did this happen after some recent work or out of the blue? I know you had the steering column out recently......~David~
Ahh okay.~David~
