Wasn’t the battery. Only other thing I can think of it being is one of the relays or either the ECM harness. Done everything else I could think of.
1989 Grand Marquis ECM removal
ok so lets step through this in a logical manner here. can you measure the following things please?
battery negative to battery positive voltage key off
battery negative to battery positive voltage key on
battery negative to battery positive voltage engine cranking
battery negative to ignition coil + key on
battery negative to ignition coil engine cranking
battery negative to TFI PWR key on
battery negative to TFI STRT engine craking
this should confirm if we have power where it should be, and if the battery is too weak to make all this happen.
again the ignition system is unrelated to the relays or the ECM harness. None of the power comes through any of that.86 Lincoln Town Car (Galactica).
no issue, just trying to get all the info together in one spot rather than going through a bunch of posts and possibly missing something.
At this point we're dealing with a mix of old car with old wiring and aftermarket parts that may or may not be bad right out of the box. Annoyingly just because its new doesn't mean it actually works.86 Lincoln Town Car (Galactica).
Those codes are probably from a low voltage condition or false start (engine started but died quickly).
edit: Thinking about this more... if you haven't changed the distributor, the PIP could indeed be bad inside. Sometimes you can tell easily as it will be getting ground up by the tone ring under the rotor. I had one die that way.
If you have replaced the dizzy, then either it's bad or it's just as I initially thought.Last edited by sly; 10-02-2023, 09:01 PM.
Originally posted by sly View PostThose codes are probably from a low voltage condition or false start (engine started but died quickly).
So yeah... stale codes.
I had that issue on the 88 MGM. The clip wasn't holding the harness snug. I zip tied it to the ignition module (one around the module so the zip tie holds the clip down) and didn't have issues after that. Hopefully if that is the issue, it's as easy a fix.
so just to confirm, does this have spark or no? Vacuum leaks won't cause no spark.86 Lincoln Town Car (Galactica).
Yeah when it wants to spark. Sparks sometimes for no reason doesn’t spark sometimes for no reason. In retrospect I don’t know why I mentioned that.Last edited by monotonorobo; 10-04-2023, 06:18 PM.
7 volts when cranking seems awful low. might be low enough that the ignition doesn't work reliably. I don't know what its lower limit is.86 Lincoln Town Car (Galactica).
I think it's 8.5 or 9V. I have a vague feeling I've read that somewhere before. Reliably is probably 10 though. I know I can't get a starter to turn fast enough with less than 10V on crank from the numerous battery replacements I've done with my own vehicles and family/friends cars.
