Originally posted by WagonMan
View Post
1989 Grand Marquis ECM removal
Surely appears to be fuel dilution into the oil. This often happens in the region between the piston rings and the cylinder bore. Other factors include leaking of the fuel injectors, incomplete combustion of the fuel, low engine temperatures, long periods of idle time and frequent short-distance driving.What I Own: 1993 Mercury Grand Marquis GS
- Likes 1
Unplug the MAP vacuum line and see if it runs. I once had one fail and it ran normal with no vac but pig rich and would barely go with vacuum, exactly the opposite of how they act with a good MAP.86 Lincoln Town Car (Galactica).
- Likes 1
has this ever run since you owned the car? If it ran normally at some point, I very much doubt its clogged injectors. They don't suddenly go bad. It happens after years of use, or years of sitting.86 Lincoln Town Car (Galactica).
It sat for about 5 years before it was in my possession. And I worked on it for a year before I had it run, changed out everything fuel related except for the injectors and rail. I always had rough idle for about 2 mins after first crank of the day and it’d cut off on hills sometimes, or if I went into reverse sometimes.
Originally posted by friskyfrankie View PostCould certainly try a GOOD fuel system cleaner. Not sure what you can get where you are so I'm hesitant to make any suggestions. By the way, when was the last fuel filter change? Just curious....
I've used ATS 505 CRF. It is not cheap but extremely effective. If cost is an issue, you can try Chevron or another high end cleaner and fuel system treatment. If there is rust still in the system you need to eliminate it completely.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostYou can pull it and see how it runs differently but it will surely run poorly by doing so.
If you wish to check for vacuum leaks, the best way is with a smoke detector or spray carb cleaner on all the vacuum lines (be VERY careful around a hot engine) and listen for idle changes.What I Own: 1993 Mercury Grand Marquis GS
- Likes 1
