Last dizzy I swapped out I used a new one from AutoZone. Worked fine for me. Make sure to lube the o-rings with oil when inserting the new one to help things slide in. The dizzy I took out was very crusty and did not want to turn smoothly. Everything i have now is all sensors and no dizzy.
1989 Grand Marquis ECM removal
I've rebuilt them but if you don't have a press to get the gear on and off, its not really a DIY-friendly task.
have a close look at the coil connector though. Have seen the wires in those break right at the plug and do this. easier than messing with the distributor.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI've rebuilt them but if you don't have a press to get the gear on and off, its not really a DIY-friendly task.
Originally posted by sly View PostLast dizzy I swapped out I used a new one from AutoZone. Worked fine for me. Make sure to lube the o-rings with oil when inserting the new one to help things slide in. The dizzy I took out was very crusty and did not want to turn smoothly. Everything i have now is all sensors and no dizzy.
to do the pickup you have to remove the gear. Its got a pin, then it has to press off. Shaft slides out, 2 screws and the pickup comes out. The extra fun part is getting it back together, the gear has to go on exactly lined up with the hole for the pin otherwise it will not go back together. I've tried getting them apart by heating the gear or just using a hammer and a pipe to drive it on, it doesn't work. At best it got stuck somewhere, at worst it bent the shaft or damaged the gear. Takes 2 minutes with a press but otherwise forget it.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postto do the pickup you have to remove the gear. Its got a pin, then it has to press off. Shaft slides out, 2 screws and the pickup comes out. The extra fun part is getting it back together, the gear has to go on exactly lined up with the hole for the pin otherwise it will not go back together. I've tried getting them apart by heating the gear or just using a hammer and a pipe to drive it on, it doesn't work. At best it got stuck somewhere, at worst it bent the shaft or damaged the gear. Takes 2 minutes with a press but otherwise forget it.
just need some on the O ring, it'll oil itself with oil splash off the timing chain.86 Lincoln Town Car (Galactica).
- Likes 1
Just get the dizzy your engine requires. I also got the "new" one and not a reman one. Looks like the new one for roller cam 302 (5.0L) is https://www.autozone.com/external-en...d17/224372_0_0
That should be the one I used as well.
If you have a 351... use this one: https://www.autozone.com/external-en...d05/193734_0_0Last edited by sly; 09-19-2023, 01:32 PM.
- Likes 1
New distributor just came in and still no spark. Kinda lost from this point, anyone got any advice? ICM been replaced along with the entire distributor, ignition coil, and ECM.Last edited by monotonorobo; 09-19-2023, 08:54 PM.
did you check to see if you have +12v at the coil, both key-on AND cranking? There are two power feeds for it and its very possible to have one but not the other.
contrary to popular belief, the ignition system in these cars is not reliant on the ECM. The ECM provides timing advance, but it will not cause a no spark condition, and you can crank the car with no ECM installed and get spark. Bad grounds are not going to cause any of this. Can cause other stupid problems, but not this.Last edited by gadget73; 09-20-2023, 04:48 PM.86 Lincoln Town Car (Galactica).
- Likes 1
