Have the box it came in somewhere in my stash. Therefore, not sure of the P/N.
Running R-134 question
I recently put a new check valve, in my friend's car, and it worked for several months (yes, an OEM part). Now he is having an issue again so when I can get to it, I need to see where the vac leak is coming from. Hopefully, not the "new" check valve! He is having the same issue you had so perhaps the valve is again at fault? We'll find out eventually. cause his "coffee can" looks good but I need to see if it hold vacuum. ...What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostI recently put a new check valve, in my friend's car, and it worked for several months (yes, an OEM part). Now he is having an issue again so when I can get to it, I need to see where the vac leak is coming from. Hopefully, not the "new" check valve! He is having the same issue you had so perhaps the valve is again at fault? We'll find out eventually. cause his "coffee can" looks good but I need to see if it hold vacuum. ...
Originally posted by Toploader View Post
Frank..............look carefully at the coffee can seams, they may look good, but push all over the top and bottom, the rust could have eaten through but not easily seen. That is how I finally discovered my can was rotted out.What I Own: 1993 Mercury Grand Marquis GS
Motorcraft YG337 is that check valve.
Thain, not on my '86 MGM with ATC. Every time I would feed gas the blower motor would either slow down or go off completely. Long story short, the bottom of the coffee can was rotted around the seams, and the vac tree on the dash was leaking. After I replaced both no longer a problem.
in non-ATC cars, the blend door is moved by a cable, and the fan speed is only controlled on the dash. It still uses vacuum to control where the air comes from though, so it will shift to defrost.86 Lincoln Town Car (Galactica).
Well, my coffee can was rotted out, and I had additional issues with the check valve, replacing both of these items resulted in high fan even at speed, or when I stomped the gas to get trans kick-down. Before the two items mentioned were replaced, the blower motor would stop or slow down when I stomped the gas, or the car was in a state of high expressway speed.
I'll be checking both when I can. Got a check valve, on order and already have the plastic version of the "coffee can". Getting tired of chasing the same issue, every few months so hope they seal the deal!What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostSo if you are on High Speed (in a ATC car) and the fan speed drops on acceleration - what causes the issue since it is not a vacuum problem?
its probably not slowing down, just the air doors are moving and the air is coming from somewhere else so you don't feel it anymore. It also shifts from recirc to outside air, and that usually does add some restriction so a bit less airflow. If it is actually slowing down, it has to be some really goofy electrical fault86 Lincoln Town Car (Galactica).
- Likes 1
its probably not slowing down, just the air doors are moving and the air is coming from somewhere else so you don't feel it anymore. It also shifts from recirc to outside air, and that usually does add some restriction so a bit less airflow. If it is actually slowing down, it has to be some really goofy electrical faultWhat I Own: 1993 Mercury Grand Marquis GS
