Originally posted by Toploader
View Post
'86 5.0 mgm alternator
More questions, always more questions;-)
So assume that the alt is not at fault and the battery again goes dead...........where else can I look at devices known to be sources of voltage drain?? I have removed the trunk and under hood bulbs, only bulbs left are the glove box lamp, and the lamps that illuminate the sun visors .
Replacement alts for these seem to come with a connector. At least the pics on RockAuto show that.
As for testing, just use the middle pin on both. Don't test the skinny wire, just one of the fat ones. A clamp meter like the one I have would be much easier, but a basic DMM with amps setting (use 10A for safety of the meter as I've seen as much as 1.5-2A on failed alts and as little as 0.1A leakage on a mostly good but leaky one).
This method can also be used to check every circuit. Pull the fuse and put the meter across the fuse terminals. You SHOULD see some leakage on the clock circuit due to the keep alive circuit from the battery. The radio will also have a little drain. Both should be less than 0.1A individually and preferably combined. If checking the dome light (interior courtesy lights) circuit, make sure to hold the button in so the lights are off if you can or just skip that one. This process will reset your clock and radio settings.
For the starter solenoid mounted wires, you can do the same thing by taking it all off the solenoid (except the positive battery cable, don't leave that dangling - might want to disconnect the negative cable before doing that and reconnect it after you have the positive reattached to the solenoid securely) and then putting the meter between the positive battery terminal and each disconnected wire individually. If you find more than 0.1A leakage anywhere, you've probably found the circuit with the issue.
Originally posted by sly View PostReplacement alts for these seem to come with a connector. At least the pics on RockAuto show that.
The dielectric grease would be rather crusty by now, but yes, that is a thing that Ford did. Not sure about the alternators though. I'm used to seeing that in light sockets that turns yellow and crusty.
Originally posted by sly View PostThe dielectric grease would be rather crusty by now, but yes, that is a thing that Ford did. Not sure about the alternators though. I'm used to seeing that in light sockets that turns yellow and crusty.
Yeah... probably dielectric grease. Not an issue as it presses away from the contact surfaces when it's in good shape. When it gets crusty it becomes more plastic and insulator than grease.
real fun when it turns to glue in the bulb sockets and you can't get the bulbs out. Have broken several dealing with that.86 Lincoln Town Car (Galactica).
Originally posted by Mainemantom View PostIf you should need a connector with wires, I have a new one in stock. Do not use the existing connector.
Tom I will check the car tomorrow, I think the other connector (3910) has a piece of the plastic clasp broken off, but I will check tomorrow... I just hope the battery is not dead, even with the alt taken out of the circuit...if so the drain is someplace else and I will be forced to bring and leave the car for my bud to keep checking everyday until he finds the cause of the drain/dead battery.
Only real issue could be dry bearings.
Regulator could have issues if it has any degraded components in it, but that's stretching it.
Originally posted by Toploader View PostNOS parts in Texas has a NOS Alt for about $120.00 E6ZZ-10346-B 65 amp. Any problem purchasing NOS as opposed to rock auto reman units, or BBB brand new examples??What I Own: 1993 Mercury Grand Marquis GS
