Clamp for door switch
    Gents is there a special clamp I can purchase that will hold in the interior light switch located near the door hinge?
    Are we talking in the door jamb? Does it not screw in as one piece?
      +1 should be just a nylon nut on the door side and the switch pokes through from inside the car (behind the kick panel).
        No on my '86 MGM it is located just below the top door hinge. Sly this is nowhere near the kick panel
          There is such a thing, used to use them at work. Kind of a spring with 2 cups attached.
          You might be able to rig something up with a coat hanger or maybe something a little thicker?
ID:	1387340 Can't remember where I got this.
              What is wrong with the switch that you have ? Is it loose or broken or is that causing a drain ? In the past, I have just replaced the switch, which is easy.
                Tom the switch is ok, just want to keep the interior lights off when I open the doors.
                  unplug the switch
                    I must be missing something. The interior lights are SUPPOSED to come on when you open the doors.
                      Originally posted by jaywish View Post
                      Click image for larger version  Name:	20230331_233948[1].jpg Views:	23 Size:	2.04 MB ID:	1387340 Can't remember where I got this.
                      Yes, this is what i was referring to
                      We used them when working on a door, to keep the battery from draining over time.
                        LOL.................correct, but when I work on the car and need to keep the doors open I do not want to drain the battery.
                          Could disconnect the battery or if you need power, you could use strong tape of a proper sized cut 2x4 to keep the switch pressed in. I am sure there are several other alternatives. That "spring tool" pictured seems interesting if someone can tell us where to find one.
                            If you have access to power, a battery charger/maintainer would also do the trick to keep the power up while you work.
                              I always just pry it out and unplug it when I have the doors open for a while.
