Originally posted by ss_mini14
Charging question :-/
yeah, pretty scary stuff but not as scary as a battery explosion, sulferic acid is a bitch'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
'83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
Bad alternators do not produce extra voltage. Bad regulators do that.86 Lincoln Town Car (Galactica).
done tried 4 :-/ All where the same.. Well with one it was at 19 degrees so eh..
I do have a thought though.. Could i have a bad reader? Cause it is still showing it as charging when the key is off and out..
Just a thought i been having )People should not be afraid of their governments. Governments should be afraid of their people.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
What do you mean it's still showing it as charging with the key off and out? Like the battery continues to read 16-17 volts?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Are you saying it's going up and down as you read it with the car off?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
In that case I'd check it with another meter just to see what's going on. It's possible you've got a problem with your test equipment...
If you're measuring the battery in degrees, thats probable the problem. You should check it with a volt meter, not a temperature gauge.86 Lincoln Town Car (Galactica).
hes not measuring temperature, hes reading the degrees of wobble on the hydrogen atoms.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
That sounds a lot more reasonable. Glad to hear you got it figured out, mang!
