I don't think the light will tell you much. The cam to ignition timing won't change much as wear occurs. The issues is the cam timing realted to cylinder location.
As for the harmonic balancer, the correct puller is a harmonic balancer puller or 3 bolt steering wheel puller is the tool to use. A jaw style will destroy the balancer.
