found this on www.clickclick.com
AOD Governor ID
AOD Governor ID
I rebuild AOD/AODE/4R70W/4R75E transmissions....Check out my Facebook page: https://www.facebook.com/pages/North...48414635312478Tags: None
given an example of each, I wonder if it would be a simple matter of boring the weight on the low speed governor out to match the weight of the high speed governor if you wanted to change one to the other. If so, its a simple piece of lathe or mill work, depending on what piece of gear you've got handy.86 Lincoln Town Car (Galactica).
yeah, I could measure the NOS piece I bought. and maybe measure the one in the hi-rev kit, just for giggle.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
might as well. Give us DIY'rs some stuff to screw up.
well, if the critical value is weight, that makes it somewhat easier. You could probably get that done with a drill, though you'd have to be very careful not to have it off center or go too far in. Careful setup on a drill press would probably get it done well enough.86 Lincoln Town Car (Galactica).
Effectively turning a lopo governor into an HO governor. Yes?1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
that's the theory.
yep, provided it is just a matter of less weight = higher RPM shift. When these were easily available, nobody would have bothered but this is what you get when things become obsolete.86 Lincoln Town Car (Galactica).
With that theory, could you also create "custom" shift points by using weights other than the 3 standard ones?1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
in theory you could tune it to your desired shift point by removing material until the shift point was achieved.
Up to a point. I expect there reaches some maximum amount of material you can remove and have it still hold it's shape. I suppose you could do a lead pour in there to drop the points back down if you go too far as well. Just would have to use the right flux so the lead will stick to the steel. I believe its acid flux to solder to steel.86 Lincoln Town Car (Galactica).
true
Originally posted by gadget73 View PostUp to a point. I expect there reaches some maximum amount of material you can remove and have it still hold it's shape. I suppose you could do a lead pour in there to drop the points back down if you go too far as well. Just would have to use the right flux so the lead will stick to the steel. I believe its acid flux to solder to steel.
also removing the governor with the transmission in the car is not very easy. The drive shaft has be removed the crossmember has to be removed and the extension housing has to come off. sometimes the exhaust has be loosened as well, to have enough room to get the crossmember out of the way.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
