all Lincoln AODs are longer than Ford/Mercury AODs. Only way to make it work is by shortening the driveshaft, totally tearing down the trans to replace the output shaft with the shorter one and using the shorter tailshaft housing from a Ford trans, or finding a 2 door Lincoln Mark VI driveshaft which is already the right length.
I was askeered of that......
Now the guy doesn't know what it came from. Just that the intake was turned the wrong way when he put it in the mustang.
Does the tag indicate what it was originally installed in?
I suppose measuring the tail housing is the best way to confirm?
Wasn't able to get there Sat, going to look @ it next Sat. Is there any indication of what it is on the tag?.
I measured my tail shaft to be 10.5", he measured his to be 11". Keep in mind that he is putting a Poncho 350 & 200r4 in his fox Mustang...
boring. Why do people do that crap? Put a Cheesler smallblock in there just to be different. No real reason to put a Chevy motor in a Mustang. They might be a little cheaper to build, but by the time you go through all the nonsense to fit it in there you've saved nothing.
