T5 Time is Now.
    Don't leave us in suspense. Get out there with a trouble light right this instant and report your findings.
      If possible set up several camera angles and have Morgan Freeman narrate.
        Yes to all of that.
        But, I think there's an ever so slight chance I've found what it was/is. And if it is what I think it is, no one would EVER guess what it is.
        Was it a loosely tensioned belt?
          busted clutch fork?
            Bellhousing bolts loose? Loose flywheel bolts are too obvious, but I'll throw that out there too. If you really feel the need to go bastard block, I have the computer for it.
            1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
              Snooki hiding in your engine compartment, trying to give it a blowjob. With teeth?
                double oil gasket on the oil filter?
                  If that was the case, the knocking would not be intermittent, and he would be leaking oil...
                    woodpecker?
                      Originally posted by johnunit View Post
                      woodpecker?
                      That would be a pretty crazy bird...
                        Well I'm 99% sure of what it was. The IAT on this car was relocated into the top of the air box due to the explorer intakes. It was held in by a big washer, and a c-clip that somewhat screwed over the threads of the IAT.
                        Ya, that c-clip, no longer exist.
                          so you say, piston go nom nom nom nom nom to C clip?lol
                            drill and tap the intake for proper sensor readings! Still why was there a c clip anyway?
                              Idk, ask Eric; I didn't build the engine. It was fine the 10k I've owned it.
                              None the less that poor c-clip has been obliterated my now.
                                i dont always do what the book tells me but my performance book says that sensor is supposed to be in the manifold, it also has somethign to do with what the computer does too.
