Auto Transmission Dimensions
This is a sticky topic.
this appears to be the current Lentech link
Ford AOD TECH The AOD transmission was produced from 1980-1993 and was used in a wide variety of Ford/Lincoln/Mercury cars and light trucks. The hydraulic pressure system is modulated through the use of a linkage or cable connected to the throttle plate, as opposed to the familiar vacuum modulator. The compound planetary gear train is similar to the earlier FMX. Its powerflow is also similar, except that in third gear, …
current TCI link
