I hate to admit it to myself, but I think my transmission is dying.
It occasionally bucks at about the rhythm of a rough idle (rather quickly) at 30-42mph with low throttle in 3rd gear, and I THINK I've felt it do it at higher speeds (50-60mph) in OD. I also think I smell a hint of burnt on the dipstick, but I'm not 100% sure.
If the tranny goes, it goes. I park the car for a few months while I save up the money for a rebuild kit (and maybe some other goodies), and teach myself how to rebuild a tranny in the meantime.
There are two main things that I think could have contributed to the demise of this tranny (assuming it is dying):
1. I think the TV rod has been at both too low and too high a pressure at various points. Chock this up to me not being very experienced and having trouble re-adjusting it properly after changing the idle speed, which influences TV pressure on a VV setup.
I had felt it slip a bit before, and very slightly adjusted the rod to a higher pressure (thinking a lack of pressure was causing my OD band slippage). It doesn't seem to have really stopped it though, and I'm worried that my slightly harsh shifts are just making it worse.
2. There was way too much fluid in the tranny when I checked today. I remember it maybe being slightly over the proper level when I checked before, but today it was over an inch too high on the dipstick. The guy I bought it from did add some tranny fluid the day I bought it, I guess he added too much. "
This probably is causing some frothing issues.
So I guess my questions are these:
1.Other than getting the TV cable properly adjusted, what can I do to slow down the demise of my tranny? driving techniques, speeds to avoid, maybe some snake oil additive? Anything like that.
2. What are some good resources for learning to rebuild and AOD? What parts/rebuild kits would you recommend? I'm thinking of putting in this rebuild kit:
3. anyone have experience with this? A TCI tech rep told me that I'd see shifts just south of 5000RPM at full throttle and that it'd be like an HO valve body with a shift kit. It also has the obvious advantage of constant pressure, as in I can't fuck the tranny up by messing with the TV rod anymore. http://www.summitracing.com/parts/TCI-436020/
4. Is there any chance that I just need to redo the OD band? Is there any point in yanking the tranny and getting in that deep without doing a full rebuild, considering my budget constraints?
