The lower transmission cooler line on the Mark VI has started to leak around the line right where it goes into the fitting on the radiator. I’m guessing the o ring is shot. Do I need a quick disconnect tool to remove the lines from the fittings and if so which one? Also once I have the line out and the fitting out of the radiator how do I get the plastic clip out off the fitting so I can replace the o ring?
Edit: I ordered new Dorman fittings since they were $6 each. Still not sure which quick disconnect took I need if any. I saw a Lisle that said it was for 5/16” line, but it sure looked awful big on the outside.
