Frankenstein T-5 Waggin' Chronicle (vast doesnt do it)
This is a sticky topic.
    This is why I am not looking forward to the exploder motor in my vic :nonono:
      Is this the only reason? I have a whole fucking list I can send you!
        how about regular gt-40 heads then tom?
        '80 Town Coupé
          They're a waste of time, Tom! Don't do it!
          Get the Ps! I did! You should, too!
            Go against the grain, be a rebel, non-conformist!! Rage against the Machine!!!
            '80 Town Coupé
              How about just clearancing the edge of the header flange a little. Just unbolt it and whack it down a little with a grinder, or do it in-place with a die grinder. Not a major issue.
                The flange isn't a problem. The socket is all the way seated on the plug. The problem is, I'd need to go straight through the header tube to get to the socket.
                  why not use a shorter socket with one of those 90* wobble joint things
                    Ah. I see now. OK, second pimp's suggestion. Flexi plug socket will help. i use one for my truck and it makes the job a lot easier.
                      Even with a swivel adapter (not to be confused with a wobble extension), it would be difficult.
                      Just put the spark plug socket on the plug and turn it using a wrench on the hex end. Problem solved.
                        I am a little cranky, so excuse me, but......... QUIT THE BITCHIN!!.
                        With an actual spark plug socket, a swivel socket to go on the end and a swivel spark plug socket, you can very quickly pull and install your plugs on a hot engine. I have to do it between rounds to check the plugs on my motor and it is not a big deal. Even if you have to stick a wrench on the end of a spark plug socket because you want to do it cheap, it is no big deal.
                        Pretty soon everyone will want to switch to a 351 just because you can't get a socket and straight extension on the lower thermostat housing bolt of a 302 and everyone will start singing the praises of an 8" over a 9" because you can get at all of the 3rd member housing bolts with a socket and a straight extension.
                        Of course I am being a little silly, but it is more silly to think that you would have to pull a header to pull a plug with FRPP P headers.
                          hmmm... a 351 swap to make T/stat changes easier. I think your on to something !!!
                            Yeah, that damn lower thermostat housing bolt!
                            Project \"Fire and Ice\":
                            1989 LTC
                            My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
                            Anton Szandor LaVey
                              That damned thermostat bolt never gave me problems...
                              And I am using P heads, because they are what is on the exploder motor...
                                I just found out the Fun Ford Weekend is going to be at the local strip the first weekend in April! I gotta bust my ass!!
                                I found out from the guy who gave me an adjustable fuel pressure regulator. Free. :worship:
                                Gonna do everything in my power this weekend and hopefully make lots of progress. Expect plenty of pictures. If I don't, you need to look at me funny and call me names. :nonono:
