Frankenstein T-5 Waggin' Chronicle (vast doesnt do it)
This is a sticky topic.
    Originally posted by lincolnmania
    dont hook up the water lines period. have heard of bored egr spacers leaking
    If you have an EGR functioning without water to cool it, you will have an even better air expander than you already have with water going through it. That is what epoxy is for. Just apply air to the water passage to test it. 90PSI of air is going to leak easier than 15PSI of water.
      I called over to the shop, again, and the guy didn't know what I was talking about when I said someone quoted me $30 for the EGR spacer work. He said they could do it, but it would be $65, not $30. Kinda wish I could remember the name of the guy who answered the phone.
      I ordered a FRPP 65mm spacer from eBay. Found one brand new for $40 shipped. The linkage bracket studs on the spacer look the same as my stock one- what's different about them?
      I'm still not exactly sure whether I'm going to hook up the coolant lines to it. Kinda depends on how the EGR stuff turns out. I don't think I'll hook up the tube going to the valve, so I'll most likely bypass the hoses running to the spacer... we'll see.
      I also went to the dealership and ordered a dust shield (block plate), the oil filter adapter (it's just a small piece that screws onto the stock filter location, yes?), and the idle air control plate. I also had the guy print out the TSB on the IAC plate so I can read up to know what it actually does.
        The mustangs have the studs on the wrong side. If you are lucky it's a lightning one. Those fit PERFECTLY and are made for a 65mm TB. I have a few stock EGR spacers that I can bore out. 20 bucks shipped...
          Why would the spacer not be able to be rotated 180*? It seems like everything would still be the same... rotated, not flipped.
            The Manifold side of the spacer is wider on the bottom to line up with the EGR passage flange. If you rotate it 180 degrees, the passage does not line up well. This only matters if you are using your EGR.
            After looking at my intakes I thought of something.............
            If you are not using the internal EGR and have the lower intake EGR hole blocked off, all you have to seal is the throttle body and the 65mm ID area of the spacer. You can flip and rotate the spacer all you want. You can use epoxy to plug the passage leading to the ID area of the spacer. This way you could use a new Mustang spacer. I do not see why this wouldn't work. I will add this (mocking it up) to my things to do this weekend and take plenty of pics.
            I still say that the most simple and inexpensive thing to do is to have your factory spacer bored out.
              the mustang egr spacer does not have the mounting studs for the throttle/tv linkage.........nevermind rig something up for the throttle since you are going with a 5 speed.........and keep the egr hooked up.........they run like poopie without an egr valve
                yeah, the bracket for the cables is totally different on a Mustang spacer. Put the two next to each other, and you'll see the problem.
                Another vote for bored out stock spacer. If you can get the brackets to fit up on that 65mm one, do take pics. I have an idea for how it could be done on a Mustang spacer without great issue, but I don't have metalworking supplies or abilities to fab such a bracket. Essentially my idea would make a bracket that bolts to the two rear-most studs on the throttle body and has a plate that the stock bracket would attach to. It wouldn't even be all that hard if I had the supplies and a light duty welder.
                  Keep the Mustang spacer and bracket bolted together..........use a Mustang TV cable and throttle cable, reaching around and pulling from the front.........
                  I plan on trying the Mustang bracket and cables. I will post pics once I get it mocked up after this weekend.
                  If by "poopie" you mean raped ape, then you would be correct. I drove my car year round with the EGR passage not functional and the valve in place hooked to the harness. If you are referring to a high mileage stock CV/GM with the E6 heads and factory cam, then the statement may have more merit.
                    I checked the Mustang cable length, and they are not long enough to wrap around. Once I get it mocked up I will be able to see the other options better.
                      Think an Exploder cable would fit with Mustang brackets?
                        It is possible...........I never had a complete Explorer cable to mess with. None of the bone yards around here save cables deliberately. It is only by chance when one is left intact on an engine. I haven't found an Explorer 5.0 still in the truck to get stuff off of either. The yards seem in a big hurry to rip the stuff out and crush the bodies.
                          I don't know what stock Mustang bracketry looks like, but I'll have access to an Explorer to examine the cable length and all that over the weekend.
                            PICS!!!!
                              PICS!!!!
                              I have a feeling I'm spending tomorrow's lunch break buying a digital camera at Wal-Mart.
                                i've heard of using the mark 7 throttle and tv and cruise cable on a towncar with the intake pointed in the stangs direction i think it was a guy over at lincolns online
