Yah, he beefed the shit outta these LCAs, also looks like he reinforced the frame between the rear spring perches... plus of course installing the deeper spring perches - are those so you can run longer coils and thus get more travel and articulation out of the suspension?
1980 lincoln body bushings.
well, really the frame is wrapped from stem to steer in 3/16 steel, all 4 sides, then molded and smoothed. there are also gussets in the perches. yes the "buckets" are there so i can lay the frame on the axle, and still fit 5 turns of coil or so. with the use of some telescopic cylinders ill be able to lock out the rear suspension, which has its own mods....lets just say its the "tow package".
Originally posted by gadget73 View PostA lot of looking was done for these, and they just don't exist anymore. The plan is to use an Energy Suspension generic body mount bushing instead. I have a set for my car, they'll get installed whenever the planets align properly so that all parties involved have time for it.
I see *something* up where the rear spring perches are, but I don't know what they are. Looks like you boxed the stock front lower control arms too?
ugh, im not really psyched about using polyurethane. doesn't flex a lot at all. whats the the part number, for summit or jegs....guessing thats where they are coming from.
energysuspensionparts.com 9.4102g
need to make up some spacer washers too to use these mounts.....they are soft poly mang......pretty nice and i was only able to get one oem body mount for test purposes and that one cost me 30 bucks......it's about 220 for the 8 sets of two bushings per box shipped
there are a lot of different durometers of poly bushing. These are reasonably soft. Its not that really hard stuff like sway bar endlinks are made from, these feel pretty close to the stock rubber as far as pliability.86 Lincoln Town Car (Galactica).
Originally posted by mrltd View PostMan that looks great! The work on the control arm looks factory. Did you reinforce the ball joint area at all, it looks like a weak spot from the pics.Last edited by 351-lincoln; 01-30-2008, 01:02 AM.
Originally posted by lincolnmania View Postneed to make up some spacer washers too to use these mounts.....they are soft poly mang......pretty nice and i was only able to get one oem body mount for test purposes and that one cost me 30 bucks......it's about 220 for the 8 sets of two bushings per box shipped
Ah OK....
The body mounts OD is a tad less than the ID of the frame mount. That's the issue. I need to get my butt in gear and get working on mine. The body moves all over the place on my car and ripped the steering column apart.Builder/Owner of Badass Panther Wagons
im going to have to go over each of my bushings and see just what kind of shape they are in. they all seemed to be in very good shape. just a few had there little metal rings pulled off when i pulled them off the frame.
Originally posted by Blaze86Vic View PostSo what is your guess on how much this thing is going to weigh all said and done? And dear god I feel sorry for whomever is unlucky enough to get in a head on with that car, because they are going to get PWNED
