I noticed today in the snow that my brakes seem unbalanced. The front would slid in the snow, but if I give a bit more the rear would grab like crazy and stop instantly.
Is this adjustable?
2000 Grand Marquis LS
Mercury Owners Group member
but yes. In general, front brakes do 80% of the braking. And the rears being drums like to lock up quickly compared to discs. You could get a brake bias adjuster, but it prolly isn't worth the time. Get 98-02 brakes on all 4 corners. That'll help!
Under normal conditions it is much more balanced. There is a ratio of traction, so as you lessen the traction quality of the surface, there becomes an inbalance between the front and the rear.
Thanks, what if figured.
Better brakes someday maybe
Have you been in a box with bigger brakes up front and discs on the back? Scott showed me how well they work in his TC, you stop a hell of a lot faster with those than the stock setup. That's why ours sucks.
'95 Ford Bronco XL -
How are better brakes going to make a car stop faster if the wheels are lock up?
My point is, if your brakes have the ability to lock the wheels up then they have the ability to hold the wheels beyond there maximum level of traction. Which means that the weak link is the tires, not the brakes. I'm not saying big brakes are not worth it. But for daily drivers, police is fine. Beyond that, you are just going to help with your brake fade characteristics, not actualy braking force.
I concur. On my Park I can easily lock up my stock tires. If and when I go to 245/45/17s maybe the stock brakes won't lock up. And probably that would be best, too much and the wheels lock up and you loose control.
If you do alot of agressive driving they would be a benefit because of less fade. If I were towing a large trailer that might be a benefit too, but my camper is small and has electric brakes.
What do the PI brakes consist of?
Easy upgrade?
Do the wagons have this already?
