What year model mounts to put 4.6 in an 84? Is it only the mounts needed or is there pedestals or anything off a donor car I need?
I just happen to have a collision catalog right here. No first hand experience unfortunately. Per the book, looks like you will need the mounts and the supports, as they are different part numbers from the boxes.
L Mount F4AZ-6038-B
R Mount F4AZ-6038-A
L Support F2AZ-6K061-A
R Support F2AZ-6K060-A1990 Country Squire - under restoration
92 mounts should work like a champ. The cross member is pretty much the same to 97, so 92-97 mounts should fit a mod motor into a box.
Originally posted by Swayze View PostWhat year model parts are those?1990 Country Squire - under restoration
