ADTR Coil Over System and what prevents this from working on the older cars?
    Seen this while browsing the site:https://adtr.net/product/ford-crown-...equipped-cars/
    Install article:
    The fronts look like it would work fine. The rears I have a question about the spring perch on the 91 and down cars. The coil over uses a plate with a bolt that slips into the spring cup and then an adapter gets bolted in place to house the coil over. Is this the difference between the 92-98 and 91 to 79 axle tubes?
    Curious why the kit would not fit the older cars.
    I have concerns about applying the entire spring load to the OEM shock mount on the front end. The frame pocket is what carries the vehicle load. That mount just provides a pivot for the upper arm and support for dampening loads. Asking it to do all three is a bit to much to ask of it IMO.
      Coilovers mounted on shock locations are used in many coilover kits for classics. I haven't heard anything breaking off ever, but I've seen weld-on reinforcements on some cars. Coilover conversions don't exist for boxes yet so I guess it'd be smart to be a bit cautious.
      Those shocks are probably high quality and all but holy shit almost 2 grand for 4 springs and shocks and a couple hunks of steel? The shocks aren't even 2-way adjustable.
      Trying to get a panther to handle real well is kinda dumb, let alone a box. But if you're hell bent on taking a fridge on a road course, maybe 2k isn't that steep. I don't know how those spring rates relate to stock, but ride sure ain't going to be as nice.
      I just want a rear sway bar and see how it goes from there...
      2005 Volvo V70 Bi-Fuel
        Chris answered my comment on FB saying something about the control arms they are using for the mod are only stated to work with 92-02, so they are listed as such. So pretty much nothing is preventing them from being used on boxes.
          The mount will not shear off or anything... what could happen... because there is so little surface area to support the load, It will deform through it over time. Basically a 1.5" dia with a .860" hole in it. That's only 2.25sqin of surface area for the weight of the entire front of the car. The material there is about .200", I think. You'd need about 24 tons to punch right through.
          I mean kudos for the ingenuity, but a proper upper mount needs to have it in double shear and the frame pocket to take the load. Use the shock hole to attach that and draw it up to the spring pocket.
          Here are gbody "coilovers" using the spring pocket. https://www.speedwaymotors.com/QA1-1...ers,38088.html
            Would there even be an advantage to a coilover in the front? The stock system already has the shock inside the coil spring. Thats not even considering the structure problems Jeff mentioned, which I fully agree with.
              Interesting... Ride height adjustment would be the main benefit, rebound adjustment as well. to be honest im not sure it's worth it. Just get different spring rates/spring heights and fully adjustable shocks. more guess work though
              -Phil
                I hear all concerns.
                So one believes the spring perch in the rear are identical between the 91 and 92+ cars?
                  I don't see why they wouldn't be- my 94 rear fit my 82 springs exactly the same way. I'm not convinced having a shorter spring with less coils, and an adjustable spacer would have the same ride quality as a longer one with more coils
                  -Phil
                    I figured out what the difference is on the rear axles... The early perch doesn't have a hole in the middle for the mounting bolts required for the adjustable perch. You would have to drill the perch and possibly slot the side to get the nut in to fasten the adjustable perch to the stock perch.
                      The upper perch on later cars also is designed to accomodate the air springs. Big hole up there for the solenoid, and its generally a different shape so it can work with either a coil spring or the basically flat-topped air spring. Thats why I gave up on the idea of fitting 90s air suspension to my Towncar. It wasn't going to happen without either a frame swap or at least cutting those upper pockets out and i was not in any way motivated to do that.
                        Copy that.
                        I was not fond of having to cut into the front spring upper mounts already. Kinda irreversible.
                        I was originally tempted but too much does not fit the older panthers.
