I'm guessing there's not much point in lowering springs over cutting the springs since mine's just a stock budget cruiser. Or are there some cheap direct fit springs for something that are readily available even here in Finland?
Just a couple questions:
- How much can be "safely and responsibly" cut off the springs?
- What hits / rubs first in a lowered box? Tie rods, wheelwells, tires running into fenders etc.
- How far would I have to go before I should take into consideration things like shocks bottoming out, roll center relocation, balljoint angles and such?
My goal is to just make it look nice and lower, nothing too aggressive. I want it as low as possible without affecting useability much. Atleast 3 regular size chicks in the backseat without the fear of bottoming out
Running the original wheels for now.
Here's how she sits currently:
Springs seem healthy, though it did seem like there was one of those weird coil blocks in one corner.
These Panthers are in ways similar to older Ferds that the coil springs will try to kill you and your neighbour when released from it's place?
And I won't necessarily need a spring compressor to get them back in after cutting x amount off?
Please post pics of your lowered boxes and tell what you did, before/after if possible.
