Does anyone follow ADTR on social media? He just posted the other day about prototyping some phenomenal trailing arms for 79-97. Even factoring in provisions for the sway bar mounting locations on boxes. I'm pretty psyched to see this happening!
ADTR adjustable trailing arms!
Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruckTags: None
Originally posted by marquis_82_withneons View PostDoes anyone follow ADTR on social media? He just posted the other day about prototyping some phenomenal trailing arms for 79-97. Even factoring in provisions for the sway bar mounting locations on boxes. I'm pretty psyched to see this happening!
After that is completed i will be sending him my smaller rear sway bar and my 1” rear bar so he can somehow duplicate it. That why we won’t have to look for parts that are becoming harder and harder to find.
Sweet! I'll be up for a set for sure! Just in time for the axle swap.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Neato! I actually have a set of custom-made adjustable upper control arms i haven't installed, as well as boxing plates i also haven't installed, lol. Also lucky enough to score good sway bars but i may not be so lucky with my future panthers so it'll be cool if adtr starts making all this crap. Be really cool if they did up a big-brake kit so we can get all the junk in one place but that may be getting greedy.
Originally posted by knucklehead0202 View PostNeato! I actually have a set of custom-made adjustable upper control arms i haven't installed, as well as boxing plates i also haven't installed, lol. Also lucky enough to score good sway bars but i may not be so lucky with my future panthers so it'll be cool if adtr starts making all this crap. Be really cool if they did up a big-brake kit so we can get all the junk in one place but that may be getting greedy.
Either way. I'm looking forward to having a real nice setup under the back of my merc and these will fit the bill nicely.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Someone care to explain the benefits of these? I obviously see that that will be more ridged, but what other purpose do they serve. What does the adjustment give you? Curious.~David~
Provide less axle rotation on acceleration from the stiffness as well to provide the proper pinion angle throughout the power band and get more torque to the wheels for burnouts.
the problem with stiffer arms is that the suspension needs that flex in order to work. Unless these have spherical rod ends to allow the rear to rotate around the driveshaft axis, you're liable to have binding problems and/or rip the mounts out of the frame if you do anything but go straight 1/4 mile at a time.86 Lincoln Town Car (Galactica).
Adjustment will be nice because I plan to run a lower ride height than stock. And will hopefully just give an overall mo4e responsive feeling in handling.. and if they come with poly bushings then hey.. bonus nachos.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Originally posted by gadget73 View Postthe problem with stiffer arms is that the suspension needs that flex in order to work. Unless these have spherical rod ends to allow the rear to rotate around the driveshaft axis, you're liable to have binding problems and/or rip the mounts out of the frame if you do anything but go straight 1/4 mile at a time.Builder/Owner of Badass Panther Wagons
If you want lateral stability for turns, you want a panhard or watts link. Stiffer arms really aren't going to do that for you. A panhard should make the shit road behavior a fair bit better, I've noticed the back end tends to dance around considerably even with good bushings. Its downright scary when the bushings are totally fucked in the back.86 Lincoln Town Car (Galactica).
