Hubcentric spacers on the front
my lathe doesn't have the swing to mount the rotor, but I can bore out the spacers easy enough. Haven't run stock rotors in a long time though, and my two Fox cars that do use those rotors run stock wheels.86 Lincoln Town Car (Galactica).
Nice! Machining things is fun. What wheels you planning to run?~David~
Problem with boring the ID of the hubcentric part of the spacer is that the wall would end up being about .0075" thick by the time it would fit over the rotor stub. I found some cheap 16" LSC turbines in pretty good shape that were just spray bombed black. my buddy is blasting and powder coating them (it's his actual job, he works for a powder coating company)
Looks good. Nice option for LSC wheels that the finish is getting a little ratty on.86 Lincoln Town Car (Galactica).
Does look nice. Get them installed.~David~
depends on exactly what you need, i may be able to help. This is just clearance, it's really absolutely not precise. The diameter i turned is not perfectly concentric with the hub diameter. I just slapped it up on the chuck and cut some matl away. If you need precision these junker lathes we have at work probably wont do it.
