Any reason you want to reduce the effective turning radius?
My Cars:
-1979 Ford LTD Landau (38K Miles) - New Cruiser -1986 Dodge D-150 Royale SE (112K Miles) - Slowly Getting Put Back Together
It seems that "reducing" the turning radius would be to make it smaller, so the car turns tighter. I can see reasons why one might want to, but with these cars it seems unnecessary.
The issue here is that the box Panther is already an incredibly agile car and can turn tighter than most vehicles I've ever been in, including many cars much smaller than them. The steering geometry plus the small wheel diameter in a large wheel well gives the car a very tight turning radius.
I don't think there is any more angle available without making stuff hit other stuff. You could try grinding down the steering stops below/behind the calipers so the spindles can turn further, but I don't know what is going to be the next stopping point (tire on control arm, tire on frame rail, etc)
Not to mention the correct geometry (turning each wheel the correct proportionate amount) probably goes out the window when the pitman arm is so far out to one side or the other, because it's going to pull the drag link out of its intended range of motion.
Are you sure you don’t mean reduce the steering ratio (less steering wheel turns lock to lock, quicker response)?
I am actually impressed with the turning radius of pre 03 Panthers (haven’t driven post 03). As compared to Fox Mustangs and straight axle trucks from the 50’s, the Panther is a vast improvement.
yeah, for the size of these things they do turn a pretty tight circle. I also don't really think there is a whole lot to be done to make it tighter either. I suppose if you cut the car at the B pillar and eliminated everything between the B and C that would tighten it up, but the car would look pretty stupid and thats a whole lot of hacking.
are you trying to solve a specific problem, or are you used to driving a much smaller car ? Parking gets very easy with these once you've had some practice. It can take some getting used to if you come from driving a little car though. The great thing about a box is that you can tell where the car ends pretty easily, so you won't hit stuff if you pay attention to it. Honestly I prefer that vs cars that have a significant amount of vehicle beyond where you can actually see from the driver's seat.
