When should I use an oversized lower ball joint?
    I'm planning to use my stock lower control arms with ES poly bushings when I do my big brake swap. The ball joints currently in there are not original as evidenced by the zerk fittings. Should I use a standard size '98-'02 ball joint or should I get the oversized version that is available?
    Also, where can I find the upper control arm bump stop for '92-'95 arms? The ones on my junkyard pieces were toast.
    —John
    1985 Ford F-150 XLT Lariat
    Only use an oversized if the hole is showing gaps around the current one.
    They make universal bump stops. Not sure they will fit right though.
      I would say never. If the stock size ball joint doesn't fit properly, you fix that with a new control arm.
        Overseized balljoints are a thing? If the arm hole is wallerd out, just get a new one. It's not like there aint a junkyard full of them in every country bumpkin locale across the states
        '80 Town Coupé
