K, will do, if you don't see anything posted by same time tomorrow that means I forgot about it so send me a PM to remind me.
Rear disc conversion question
Originally posted by BlackVic_P71 View PostThe box should have a 1310 u-joint and an aero should be 1330, measure to be sure.
LOUD EXHAUST IS FUN! AM I SHOUTING?1990 Country Squire - under restoration
Originally posted by His Royal Ghostliness View PostOh fuck the '92-up brake hose arrangement:
#1 fuck having the brake hose so close to the tires, tire are known to com apart and tear stuff in their near vicinity to pieces.
#2 fuck needing to pop the brake calipers off for just about any work that requires supporting the car by the frame with the axle hanging way down. You know, work like replacing your rear shocks or springs. And if you're not extra careful where you attach the brake hoses on the frame, you risk ripping one (usually driver side) apart if the suspension goes into max droop position even with shocks still attached and thus limiting down-travel.
#3 fuck running brake lines first way the fuck back behind the axle for the driver-side hose, then way the fuck up over and across the frame, then way the fuck forward of the axle for the passenger-side hose.-Steve
Originally posted by Tiggie View PostThis. Brain fart on my first post. But measuring is good away. 1310 should be 3.5 inches.
LOUD EXHAUST IS FUN! AM I SHOUTING?1989 Country Squire - Twilight Blue, 347 stroker
Originally posted by BigMerc96 View PostI fail to see any of these issue with the factory Aero/whale configuration.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostKeep in mind that his idea of "sufficient" is being able to do Dukes of Hazzard style jumps over the zombies during the apocalypse with zero chance of anything going wrong.
I had a wheel come off my car, and my 92+ style lines were not affected. *shrug*86 Lincoln Town Car (Galactica).
Steel is roughly 3x the weight of the same size hunk of aluminum.86 Lincoln Town Car (Galactica).
Originally posted by BigMerc96 View PostI have owned 2 Aeros and a whale, and I've worked on many more of them. I even replaced the hard-lines on my Town Car. I fail to see any of these issue with the factory Aero/whale configuration. I've never removed the calipers to do anything to the rear of the car except when I pulled axles. There is enough length in the hoses to allow for full suspension travel without pulling. The only time I came close to pulling on the hoses was when I had the shocks unbolted to lower axle and remove coil springs. Yes the hard-line routing doesn't make the most sense, but, its not difficult to run. From the drivers side hose it goes up a couple inches then its a straight shot up and over the gas tank where it comes out and turns forward and runs a further foot or so and connects to the other hose. I agree that if the existing lines are good, you can make the box brake line configuration work, it is not unlike how a lot of trucks and other solid axle vehicles are plumbed. If the lines should be replaced anyway, then there is nothing wrong with the Aero/Whale configuration.
When it comes to running the new lines, the aero/whale sucks cause you got fairly limited space to work with between the body and the frame. Whereas with the full axle-mount routing the main lines is rather easy to make reach the factory center hose location on the frame, and from there on out you just let the axle hang by the control arms and pull up a chair and sit behind it and under the fuel tank and the two pieces are right there in front of you - no need to reach up above your head while trying to guide the crossover line towards the passenger side.
As far as hoses length is concerned, factory aero/whale setup is pretty borderline, I just worked on a full-factory whale last week and had I popped the shocks off the axle with calipers still in place I'd be in need of new caliper hoses, this from the weight of the axle alone (air springs were already deflated). And being that a conversion on a box is just that, it's quite easy to fuck up the ideal location for the bolts that retain the hoses to the frame, and end up with less hose length than suspension travel.
So overall it boils down to that doing the lines box-style is simply easier and faster for me, with the added benefit of reduced chances of major fuck-up due to circumstances that are beyond my control.The ones who accomplish true greatness, are the foolish who keep pressing onward.
For the record I don't think even 4" of clearance is acceptable for an offroad vehicle, therefore I'd much prefer to keep the caliper hoses as close to the axle housing as possible and then use hard lines to bring the connection between the axle and the restd of the chassis out somewhere in the middle of the frame where it's well protected against tires and anything they may grab a hold of and sling around. Which is exactly what the rear of a box Panther ends up like if the factory style center hose and hard lines are retained. And yes I realize that Panthers are not exactly offroad-friendly, but principle still applies.The ones who accomplish true greatness, are the foolish who keep pressing onward.
In any case, Elias, take a look at this post here:
If you don't have a welder you can easily make mounting brackets out of flat stock (steel is cheaper to buy and easier to cut, but aluminum is easier to drill), bolt them onto the housing via the smallest-diameter pair of holes punched out the rear wall of the mounts for the lower control arms (you can see said holes in the 1st and 3rd pictures).The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by His Royal Ghostliness View PostIn any case, Elias, take a look at this post here:
Also what would y'all recommend for painting the rear or the steps in painting it and materialsLast edited by Elias; 09-04-2017, 10:28 AM.
