Rear disc conversion question
    clearcoat it. Aluminum oxidizes fairly quickly.
    This. But do so after the U-joints and yoke and flange are installed, as that job will mar some of your freshly shined up parts. Degrease with acetone before spraying it too.
      Do y'all think the clear coat will stick. What type do y'all recommend engine or caliper clear coat
        IDK if it exists but look for some designed for aluminum.
          don't know that the type matters. Its not going to get terribly hot.
            I don't think any paint will stick to that very well but as long as it spins around in place like a nice driveshaft and doesn't touch anything you shouldn't see a problem.
              Well I like to think more is better, so I'd fill the whole thing but I think there'd be an issue with thermal expansion & it coming out of the vent hole... ...
              I didn't have a close enough look when I did mine, but I would guess the fill hole is at a level where the fluid will get into the axle tubes to reach the bearings without being high enough to coat the axles and get flung around. I know there's something about the proper level being a little below the fill hole, so technically, people who fill it until it starts coming back out are overfilling it a bit.
              When does balancing become an issue? AFAIK, regular rust-prone driveshafts aren't supposed to be oil sprayed due to a concern with the balance. Polishing and clearcoating aluminum would seem not to be significant (esp when regular driveshafts are okay despite lots of rust coming off of them), but better safe than sorry.
                I can't imagine you'd get enough weight out of clearcoat to throw the balance. If you did a half decent job it'll be fairly evenly distributed anyway.
                More oil is not better though. It needs enough room to expand without puking out of the vent on the axle. You can massively over-fill it and it'll just puke out until its where it needs to be, as long as the vent is good. Otherwise it'll blow the seals out and puke out way too much oil all over your brakes.
                  Bare aluminum oxidizes immediately. That oxide layer protects it from further corrosion, unless that layer is subsequently damaged.
                  And I thought if you used Dino gear lube it had to be changed every 3k or 3 months?
                    ... And I thought if you used Dino gear lube it had to be changed every 3k or 3 months?
                    That was covered recently:
                      Right, that's what I was getting it. I just had synthetic 75W-140 put in our Mark VII
