yeah, the teardown is expected, just didn't know if he was planning to do it today. Used axle would get the shafts pulled for inspection and new seals at a bare minimum. More depending on the inspection results of course.
Rear disc conversion question
Originally posted by gadget73 View Postyeah, the teardown is expected, just didn't know if he was planning to do it today. Used axle would get the shafts pulled for inspection and new seals at a bare minimum. More depending on the inspection results of course.
yeah, common. The friction material glue fails and it falls off. Shoes are actually on clearance for under 10 bucks on rockauto. They a complete piece of cake to change while the axles are out, so you may as well replace them.86 Lincoln Town Car (Galactica).
Originally posted by Elias View PostStill not sure if I wanna keep the original one probably get one of these instead I'm leaning more towards the moser one.
LOUD EXHAUST IS FUN! AM I SHOUTING?1989 Country Squire - Twilight Blue, 347 stroker
You could probably add a drain, but you can always fill through the stock plug on the front.
Originally posted by DerekTheGreat View PostI like the Ford one but isn't the fill plug a bit high? Also, is it possible to find one like the factory cover but with drain/fill plugs? I don't need the fins..
As for the stock cover with extra plugs, got a welder? I've added plugs on truck axles that are liable to get submerged in water, makes the obligatory oil change after the deed much easier.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Well I like to think more is better, so I'd fill the whole thing but I think there'd be an issue with thermal expansion & it coming out of the vent hole...
No welder here and zippo welding skills. If you were to make me a cover & paint it black like my factory one I would be forever grateful. An estimate of the price would be nice1985 LTD Crown Victoria - SOLD
Oddly enough the stock one manages to contain the oil in an entirely satisfactory manner without an additional cost. When I change the oil again in 10 years or so, I'll just deal with cleaning the silicone off at that time.86 Lincoln Town Car (Galactica).
Okay so I think I found some places to rebuild the rear they are asking 300 + parts and one is askig 450 + parts. What y'all think is that normal or high and do any of y'all know the entire parts list I would need. To rebuild the whole rearend.
clearcoat it. Aluminum oxidizes fairly quickly.86 Lincoln Town Car (Galactica).
Originally posted by Elias View PostOkay so I think I found some places to rebuild the rear they are asking 300 + parts and one is askig 450 + parts. What y'all think is that normal or high and do any of y'all know the entire parts list I would need. To rebuild the whole rearend.The ones who accomplish true greatness, are the foolish who keep pressing onward.
