Well there are many things to consider with brake feel.
Assuming the fronts look ok. i.e. no odd uneven wearing of existing pads and no ridges in the rotors. No fluid leaks. master and booster working properly, fluid not decayed to extremes.
Then in my suggested order:
1) Get the rears working properly. (I do recommend converting to disk when time is available at least replace outer wheel bearings and seals while you are swapping to disks.)
2)
a. Select a different pad material. There are many many formulations out there.
I share the "Centric Extended Wear" as a solution to grabby brakes. They are not as aggressive when cold but don't fade as much when hot. All brake pads are a tradeoff in performance characteristics, like tires are.
b. I do recommend an upgrade to the 98-02 brakes, this becomes economical when overhauling the front end steering and suspension. Improvements are more heat dissipation, larger brake contact area, an easier method of caster and camber adjustment, the requirement to use bigger wheels which arguably increases the selection of wheels and tires.)
c. The 92-97 front brakes use a separate hub and rotor design but other then the ability to more easily and cheaply replace rotors and increase the selection of rims you can mount (you can continue to use the 15" and also use more 16" as the spindle on the 92-97 is shorter) they offer no additional braking capacity. The calipers are the same as the box calipers and iirc even use the same pads.
d. Booster and master will also likely provide a different feel as to pedal pressure required.
Final comments;
Even if you do upgrade to bigger brakes, rear disks, new master etc. you still need to tune the selection of pads. They are the most direct and easily changed item to affect brake feel and actual performance. Like anything, suit to taste.
MAKE SURE YOU REPLACE RUSTY BRAKE LINES IF YOU WANT TO EVEN HAVE BRAKES.
2)
Final comments;
