Since I need 16" wheels for the brake swap, I've been looking into what tires to get before I do it.
I've been planning to get the Mark series turbines (Hollander #1573) and I want to get the same tires I have now, General Grabber AT2s, for the new wheels.
Well I've run into a bit of a problem. The tires I have now are 225/70R15. These are rated for severe snow and they work great for anything I throw at em.
However, once you move up to R16, the smallest size that is rated for severe snow is 255/70R16. These are 2.7 inches taller and an inch wider, though this will probably differ with factory-spec tire pressure. While this is great for putting power to the ground, I'm very worried about the front tires rubbing during turns.
I could get spacers if it will be a problem, but then it'd probably be wise to upgrade the ball joints.
I'm not sure what to do here.
The Hollander #1573s are 16x7 with 25mm offset.
The sizes list for the tires is here: http://generaltire.com/tires/custom-rides/grabber-at2
And yes, I really do need tires rated for severe snow. This last winter we had two blizzards. I had to excavate my car from 6 inches of snow one morning. These tires laughed at the snow and ice. They actually grip on solid ice.
